radio install using existing saab amp
Results 1 to 2 of 2
Thread: radio install using existing saab amp
    Saab Fan
    Jan 2014
    australia
    68
    Hi
    I have a 2001 93 and I want to install an aftermarket head unit, but I want use the existing Saab amp to drive the front door speakers.
    As I understand the amp gets its signal via a connection from the factory radio.
    The new headunit has a plug to connect an amp, can I connect that to the existing amp.
    What I would like to end up with is the new radio driving the front & rear speakers and the existing amp driving the front door speakers, as per factory set up.
    Any suggestions please
    Re: radio install using existing saab amp
    Hello oldjocktom, if the lead on the new head unit is a single wire possibly marked as " amp " then yes you just connect to that as that is the power feed to the amp , so all will be as before once fitted .
    Hope that helps. .
  4. Remove Advertisements
  1. cd player install using steering wheel controls
    By oldjocktom in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 01-28-2014, 03:11 AM
  2. Changing my existing 6 cd in-dash unit for a brand new one, extra piece on top
    By Al's-Ragtime in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 01-08-2014, 09:08 AM
  3. Replies: 4
    Last Post: 05-26-2013, 03:55 PM
  4. Replacement Key or Re-program existing one ?
    By wini in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 03-21-2013, 12:44 PM
  5. Replies: 2
    Last Post: 04-05-2012, 01:28 PM
