2001 9-3 Check Engine Light
Results 1 to 7 of 7
Thread: 2001 9-3 Check Engine Light
    May 2018
    Richmond VA, USA
    12
    Hello all, I'm new here and welcome all the info and help to keep my 9-3 running well. We live in Richmond VA, USA. Our Saab has 99000 miles and I'm not sure when the plugs were changed and I'm pretty sure the DI cassette is orginal. Have been working on the recent check engine light which when I had the codes pulled show a P1312 and P 1334. I've have replaced the vacuum lines, spark plugs and will replace the DI cassette as soon as it shows up (here tomorrow).
    The light never comes on while driving and once reset stays off for a while then comes back and does go off after a few starts, but returns. The car runs the same weather the light is on or off, at least by the seat of the pants (nothing different in performance).
    Any thoughts or suggestions will be greatly helpful, thanks, Tom
    5,048
    Re: 2001 9-3 Check Engine Light
    I hope the DIC made by SEM..the codes you mention are a sign of the DIC going south..replace plugs at the same time as the DIC..
    Buy cheap pay twice..
    Super Moderator
    Oct 2002
    Kippen, Stirling
    2,681
    tomringo,
    As aerojon suggests, this could be a sign that the DI casette is on the way out. 100,000 miles is about right for the life of these. The codes mean: 1312 - misfire cylinders 1 and/or 2, 1334 - misfire cylinders 3 and/or 4. The ecu stores up the count of misfires and the number of starts and throws the code when the ratio gets too high. As you have found, this makes no difference to how well the car runs.
    I've had them fail gradually with obvious misfires becoming apparent and also had them go suddenly, once when half way round a roundabout and once when trying to start a previously running car. I carry a spare for these eventualities.
    A new set of plugs could also help if they have been there for a long time. The plug gap increases as the electrode erodes. My manual suggests 25,000 miles but I always replace around 12,500 miles / 1 year unless I have fitted Laser Platinum which last up to 50,000 miles. I use NGK PFR6H-10
    Paul @ Kippen.
    May 2018
    Richmond VA, USA
    12
    Thanks people, will report back as soon as the DIC arrives and goes in, Tom
    May 2018
    Richmond VA, USA
    12
    New DIC has arrived and is in along with plugs. We'll see if the codes stay away, thanks again.
    Only use NGK plugs - the stock plug for the ng900 or the og9-3 plug. Gap to the later .9mm side of the spec.
    May 2018
    Richmond VA, USA
    12
    Well 650 miles without a check light coming on and this morning it came on after I had driven it about 5 miles and then shut it off for about an hour. Light came on when I restarted it. Will have to get the code pulled and see if this something new or the same as before I changed the plugs and the DIC. Stay tuned for more I guess.
  9. Remove Advertisements
  1. 3.0 TiD 9-5 intermittent Engine Malfunction (check engine) light on dash
    By eethon in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 06-28-2014, 06:30 PM
  2. Check radiator and check engine light + erratic idle.
    By prowlingtiger29 in forum Saab 9000 (1984 - 1998)
    Last Post: 08-31-2010, 05:43 PM
  3. Check Engine Light Tranny Light
    By scoll7567 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-01-2010, 04:36 PM
  4. Check radiator light, now check engine light
    By revok in forum Saab 9000 (1984 - 1998)
    Last Post: 03-07-2010, 06:02 AM
  5. Check Gear Box/Check Engine Light, starts in third!
    By eggloaf in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 07-18-2008, 07:43 PM
