97 saab 9000 cs 97 9000 aero conversion
Results 1 to 3 of 3
Thread: 97 saab 9000 cs 97 9000 aero conversion
    i bought a 97 saab 9000 cs im wondering if i could swap a 97 aero ecu and turbo ?and would that give me same amount of hp as a aero?any advice would be great thanks everyone!
    Super Moderator
    Oct 2002
    Kippen, Stirling
    2,681
    Re: 97 saab 9000 cs 97 9000 aero conversion
    garyjames,
    Is the cs a 2 or a 2.3 litre ? If the latter then you're well on the way. You need to check that you have an intercooler and an apc valve ( little spool shaped thing with an electrical connection and 3 rubber pipes located on the right end of the water radiator. A lot of LPT ( low pressure turbo's ) were fitted with one or the other.
    You will need to swap the VSS ( vehicle security system ) chip that is mated to the Aero ecu or have its function 'deleted' from the ecu's memory.
    Alternatively you could just have your existing ecu re- written to give more ooomph.
    Paul @ Kippen
    May 2017
    chester, england.
    5
    off the top of my head, the auto was limited to 210bhp, whilst the manual had 225bhp. if you've already got some form of turbo, the best tweak i ever did was to fit an after market turbo dump valve. the improvement in low rev boost, and thereby engine pick-up, was substantial. but do be aware that if you're going to increase power, you really do need to up-rate your suspension and brakes too.
  5. Remove Advertisements
  1. Saab 9000 308mm brake conversion kit
    By n1038406 in forum Saab Parts / Accessories, FOR SALE and WANTED
    Last Post: 03-27-2010, 03:10 PM
  2. SAAB 9000 2.3LPT to FPT Stage 1 Conversion Kit
    By Pug205GRD in forum Saab Parts / Accessories, FOR SALE and WANTED
    Last Post: 04-01-2009, 09:14 AM
  3. LPG Conversion for 9000 in West Country
    By epilim in forum Saab Recommendations
    Last Post: 10-27-2006, 12:49 PM
  4. 9-5 to 9000 engine conversion
    By 9000CST in forum Saab 9000 (1984 - 1998)
    Last Post: 03-14-2004, 02:02 AM
  5. 9-5 to 9000 engine conversion
