Aircon blowing cold rear outlet blowing hot
Results 1 to 10 of 10
Thread: Aircon blowing cold rear outlet blowing hot
  1. #1
    Saab Junior
    Join Date
    Mar 2012
    Location
    Perth western Australia
    Posts
    37
    Hi my aircon blowing cold whilst rear centre outlet blowing is hot. 95 griffin 1999. I am new to this car so maybe have something set wrong. Any ideas anyone?
  2. Remove Advertisements
  3. #2
    Saab Afficionado
    Join Date
    Dec 2003
    Location
    Peterborough,Cambs,UK
    Posts
    1,130
    Re: Aircon blowing cold rear outlet blowing hot
    First thing to do is run a diagnostic check on the ACC panel and then look up the fault codes
    Press ACC + OFF at the same time with the system running.
    The SID will show if you have any faults, the left gives the number of faults
    and the right side will give the code number.
    I dont have a list of fault codes but they will be in your manual.
    If you dont have a manual you can get a pdf one below
    http://www.saabinfo.net/files/pdf/SAAB_9-5MY01.pdf
  4. #3
    Saab Junior
    Join Date
    Mar 2012
    Location
    Posts
    37
    Thanks mate, but I do not have an 'ACC' button only an 'auto' button I tried the auto button with the 'off' button and nothing happened but it switched off.
  5. #4
    Saab Junior
    Join Date
    Mar 2012
    Location
    Posts
    37
    OH OK i tried it again and got it to work. It first read "0" on the left then after a while 13 apeared on the right then the left changed to a '1' after a while then '2' Am trying to download the PDF Having a few probs but interesting to find out what is wrong.
  6. #5
    Saab Junior
    Join Date
    Mar 2012
    Location
    Posts
    37
    OK I got the code '08' If i could swear on here I would! Am told it is an expensive fix!!!!
  7. #6
    Saab Afficionado
    Join Date
    Dec 2003
    Location
    Posts
    1,130
    Shouldnt be too bad -its a common fault with the internal blend doors and/or shaft.
    This might be what you need
    http://www.thesaabsite.com/95/FAQ--h...uminum%29.html
  8. #7
    Saab Junior
    Join Date
    Mar 2012
    Location
    Posts
    37
    Thanks CJ your a champ!
  9. #8
    Saab Afficionado
    Join Date
    Dec 2003
    Location
    Posts
    1,130
    Glad to help - usually the kits crop up on Ebay and I believe partsforsaab do them here in the uk
    Not sure about OZ though.........
    The instructions below look fairly good.
    http://www.autopartsapi.com/eEuropar...structions.pdf
  10. #9
    Saab Junior
    Join Date
    Mar 2012
    Location
    Posts
    37
    HI, Pretty sure it is the blend box lever. Having read some old posts that said it would cost around 2K plus i was worried. Just rang kieth Mccrackem motors here in Perth they quoted me.....wait fo it...........$120 or 66 pounds!!!!
    if it were not for these guys I would not own a saab. Tanks for setting me right CJ.
  11. #10
    Saab Newbie
    Join Date
    Nov 2013
    Location
    Surrey
    Posts
    7
    Just repaired the AC on mine just in time for summer. Front seat passengers starting to cook. Easy fix for me no parts needed,just the motor cogs needed tapping in so they re align with the actuator. Easy fix in the end.
  12. Remove Advertisements
  1. aircon blowing hot instead of cold
    By willo in forum Saab 9000 (1984 - 1998)
    Last Post: 08-20-2009, 03:32 PM
  2. Aircon blowing cold in front and hot in back
    By neil170 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-16-2006, 06:26 AM
  3. Blowing hot and cold
    By ursathedog in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 09-27-2005, 06:31 PM
  4. Rear air-con blowing hot when front needs cold
    By J i m s t e r in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-17-2004, 07:07 AM
  5. Blowing Hot & Cold!
    By cbullock in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 04-11-2003, 05:52 PM
