Vert seat tilt mechanism not working
Results 1 to 2 of 2
Thread: Vert seat tilt mechanism not working
  1. #1
    Administrator kez's Avatar
    Join Date
    Aug 2011
    Location
    uk
    Posts
    7,086
    Looking at the parts diagram, there are two cables. One from the handle that releases the tilt and another that goes on from there to release the slide. Are they broken, stretched or detached?
    Item 11 is the "Slide release cable". The other cable from the handle is No 24.
    you need to locate cable 24 to make sure it is connected and or check the cable for the tilt of the seat back has the correct tension on it, so it pulls cable 11.
    This is what I found and how I fixed it
  2. Remove Advertisements
  3. #2
    Join Date
    Aug 2011
    Location
    uk
    Posts
    7,086
    Re: Vert seat tilt mechanism not working
    Many thanks to Times5 for providing the above information
    just to add if you feel the above mentioned cable has stretched you can source a brake cable end such as in the picture below, this will hopefully provide you with enough tension on the cable
  4. Remove Advertisements
  1. A heated seat stopped working.... (9-3 Vert cabby 2005)
    By martfcp in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 11-25-2011, 06:56 PM
  2. 9-3 convertible seat tilt problem
    By basinite in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 12-19-2010, 12:03 PM
  3. Floppy seat tilt lever!!
    By Hartz777 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 04-06-2006, 04:17 PM
  4. Seat tilt and slide
    By Aly in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 01-15-2006, 01:40 PM
  5. Tilt/Slide Drivers Seat
    By SplitBusKev in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 02-04-2005, 04:32 AM
