SAAB 9-3 2006 TiD ACC AIRCON NOT WORKING - EVAPORATOR SENSOR ERROR -40
Results 1 to 3 of 3
Thread: SAAB 9-3 2006 TiD ACC AIRCON NOT WORKING - EVAPORATOR SENSOR ERROR -40
    Jul 2013
    Buckinghamshire
    1
    Hello,
    I have often looked at the site but never had the need to post thankfully due to the excellent shared information.
    I am hoping someone will have an answer to this rather annoying issue with the ACC. I have a UK 2006 Saab 9-3 Tid Vector Sport which is superb in every way but this week the aircon decided to stop working and what a perfect week to play up in 32 degrees!
    I took the car to a specialist who has done the following:
    • Regas system, pressure tested and all ok.
    • Compressor confirmed working fine without issue.
    • Fault read using Tech II and showing Evaporator sensor reading -40
    • He advised the evaporator sensor is not one where it is supposed to be.
    • He has removed other aircon sensors (outside/cabin etc) which apparently confirms they are working through error messages on the screen and Tech II.
    Having googled the issue there are several people who have experienced this evaporator sensor error and each time there is a different reason as to why it is throwing up the non existent sensor (compressor/leak/fan control box pins corroded). I advised him to check the fan control box as per another thread but that is all dry and all pins in tact and as mentioned there are no leaks and the compressor is working.
    He has now drawn a complete blank other than finding an ACC wiring diagram to insert a bridge so that it thinks it's functioning, and I am unable to find one for the year of the car. I am also not convinced that this would be the answer as everything was working fine before.
    This obviously isn't an isolated issue, does any one have any idea how to resolve?
    Seamus.
    5,048
    Re: SAAB 9-3 2006 TiD ACC AIRCON NOT WORKING - EVAPORATOR SENSOR ERROR -40
    welcome to SS..
    get the tech to check the fan control module on the fan cowling..
    Buy cheap pay twice..
    I'd get others to bridge the sensor..... Probably a good fix......... But if ya did it yaself & it all came on top ..... No where to run
  5. Remove Advertisements
  1. Saab 9-3 2006 tid fuel filter sensor?
    By ottoman in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 07-14-2017, 07:51 AM
  2. SAAB 9-3 ACC Rattle & Buzzing - ACC Sensor Removal & Cleaning
    By 93Coupe in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 02-20-2014, 02:11 AM
  3. 2006 Saab 9-3 2.0t airbag error
    By btm5788 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 05-23-2013, 09:17 PM
  4. ACC aircon not working
    By bc109 in forum Saab 9000 (1984 - 1998)
    Last Post: 08-12-2012, 07:27 AM
  5. Wanted saab 9000 aircon sensor part no 9630740
    By Andy b8 in forum Saab Parts / Accessories, FOR SALE and WANTED
    Last Post: 02-28-2008, 03:49 AM
