Refurb Wheels
Results 1 to 11 of 11
Thread: Refurb Wheels
  1. #1
    Refurb Wheels
    From the off I will take is as read that you have taken the wheel off & its not so badly damaged that its gone flat..... We are just tidying up the aesthetics here.....
    A lot of specialist wheel refurb companies will tell you that you need to have the wheels x-rayed & professionally jiggered about with ........ Well that maybe true. But you can get brand new Saab alloys from a dealers for around the £50 mark. The 17" jobbies I've seen, so you might consider this before making a decision.
    All in the bits & bobs I bought to refurb cost me in the region of ..... Umm £30
    I started by whipping the wheel off & shoving the spare on so at least the car was usable while your getting busy....
    Attachment 0
    Clean the surface of the wheel up with some paint thinners on a rag, or some white spirit ..... We are degreasing the proposed painted area.... then use say a 180 grit wet & dry abrasive paper to scratch up the surface. I use one of those delta tipped detail sanders usually if I have a fair bit of prep to do... Just beware that the wheels are not steel they's a alloy, thus quite soft, so easy with the electric sanders ..... Pends on how fussy you are with your prep work ...... I didn't really have the motivation to be over scrupulous today.... The car is nearly 10 years old & has the odd scratch on it ....... Its up to you how far you go as you can see I didn't knock myself out with effort here.
    I mixed some of this up ...... About a teaspoons full
    And lightly applied it to the areas that had some kerb rash
  2. Remove Advertisements
  3. #2
    Re: Refurb Wheels
    After the filler had cured.... Lets say an hour later.... It depends on the mix proportions, type of filler & ambient temperature how long this stuff takes to dry ..... Today it was 31*C here so it went off in 20 mins flat. (Due to the small quantity I made up, I only had about a four minute window to apply this stuff)
    Anyways once the filler is dry its time to get busy with the 180 wet & dry & I lightly sanded the area ..... Let me stress the point here LIGHTLY SANDED..... We are not trying to de-rust the Titanic here, as you can see on the picture I have feathered the edges carefully & the kerb rash is looking better.
    I find this to be the easiest way to mask off the area..... (Cheap too)
    On with a coat of primer & let it dry .......
  4. #3
    Re: Refurb Wheels
    When dry I tend to check that the vast majority of the imperfections have gone, if not you back to a little more filling & light sanding
    then I use 1200 or 1500 grit wet & dry to take the surface down nice & smooth ..... Remember we are flattening the paint here, not removing it.
    Then on with a coat or two (Ideally at least two) of silver spray, aluminium spray or in my case a Product called silver wheels, by Tetroseal
    http://compare.ebay.co.uk/like/40050...ff14=65&ff19=0
    I have used Tetroseal grey primer, Silver wheels & clear lacquer on this project..... You might want to shop around for it.... I think I pay £4 a can for it ...... But I guess it all depends on how many cans you want etc etc
    I have found that the Tetro paint products are quite forgiving as far as hiding slight imperfections & the main thing I like about their aerosols is the nozzle generates a really good controllable fish tail shaped spray pattern, which allows you to put more or less paint on as required....... When painting either choose a calm still day, or take it in the garage.... If you have a old pair of glasses ... I'd wear those, because this stuff gets everywhere... Leave the garage door open too because this stuff generates quite a pungent smell...... Please don't spray pain't in the house because you will get in trouble off the Missis ..... For both the stink & the over spray as I said gets everywhere.....
    So after two coats of silver, it really needs three coats of Lacquer.....
    As you can see..... Within a hour I managed to achieve this .......
    Once at this stage leave it all alone for a good two hours, & don't attempt to refit the wheel to the car for a good 24 hrs ..... These layers of paint really do need this amount of time so set.....
    As you can see I didn't paint the back of the wheel, you could its up to you ...... You could even paint the back of the wheel a different colour..... I suggest candy pink ..... Or lime green
    The big ones here are to ensure no grease including off your fingers get on the surface that is to receive the paint.... Nothing sticks to grease so keep it clean .... Use a microfibre cloth to remove the dust & remember not to shake out the dust from the rag while the paint is drying ....... Well not in the same area anyways.
    If a fly or whatever glues itself to your newly painted surface..... Leave it till its properly dry. Dig teh fly out of the remaining hole & splodge a bit of body filler in the hole .... Feather it out.... & repaint ...... If you try grabbing the fly when the surface is wet you will in most probability make the damage worse ........ (I wish I hadn't done that, etc etc...)
    If you really want to be the talk of the neighbourhood you could apply some tyre slick before you put the wheel back on ........ Always good to be considered a fussy git by your neighbours ...... I get mine from here ...... Not the cheapest I know.....
    http://www.valeterspride.co.uk/5-lit...sing-209-p.asp
    This company does a lot of very good quality cleaning products, however know this, Some of them are very strong & require diluting..... READ THE LABEL & always test a new product on a inconspicuous area before going mad with it.... So remember these are pro grade products & not the stuff that you get from asda .......Be careful
  5. #4
    SaabScene.com Premium Member
    virtualm's Avatar
    Join Date
    Jun 2011
    Location
    UK
    Posts
    1,136
    Re: Refurb Wheels
    Nice work! I've only got top trumps for masking - do you think they will work? They are my favourite gumball 3000 ones I take on holiday though. Lol at you with the playing cards....
    Can I just add my 2p's worth? A few years ago I kerbed one of the alloys on my previous car, did what JM did above and it came out a different colour to the others - friggin hell looked like crap, so I ended up paying to have them all refurbed. So be warned if your going to try this - watch the colour matching!
    MY09 TTID custom remap 238bhp & EGR delete - Sold
    MY10 Nissan 370z GT
  6. #5
    Re: Refurb Wheels
    I'm currently refurbishing all of mine ...... You know I didn't think of that (Colour mismatch) ....... But my advised price of £30 was for the stuff to do five wheels ..... Yeah five ...... I bought a extra alloy from a dude who was parting out his 95.... I dunno why he was doing that but £20 for the wheel £55 or so for a new tyre, took that plastic doofer outta the boot (That w0t holds the space saver spare aloft) with a club hammer ..... No I didn't actually need a hammer that big, but it was new & I just felt I should use my new tool for something ...... Anyways the boot carpet only sticks up .5" higher than it should..... No biggie to me ...... So Now I have a full size matching spare ...... & a spare space saver wheel leaning up against my bedroom wall ...... Gonna have to find somewhere to put that.
    I guess if you only really needed to refinish one wheel, it wouldn't be too much of a hassle to do two ...... Front & back ...... Both the same on the same side ? ......
    I've been considering colour coding my wheels ....... My car is Steel Grey, So steel grey wheels might (Or might not) Look too chavvy ? I dunno .......
    While I'm here ....... If you bunch of un-cooth reprobates fancy looking http://auto-paint.co.uk/carpaint/ you will find they do really good stuff for both the talented DIY'er (Like me) & Pro's a-like ...... I really recommend their touch up bottles..... There's none of the usual three containers of paint that the dealers & halfrauds sell...... Its a un-pretty bottle of paint, the cap is a brush and you just poke it on to your stone chips & that's it (Shiny fix) ..... Should you find after a year or so your paint is going a bit thick & gloopy, nip to your local body shop & take a lil jam jar with a screw top lid & say ...... just this ..... Well this is what I said: "Scoose me chief..... Could I have a bitta thinners plz, I'm going all gloopy here" ..... They laff, you tell em you have some two pack touch up that's a bit thick ...... They will twitter on about you needing hardener for two pack..... You say well let me give it a go ....... They give you half a jam jar of thinners, you chuck them a fiver & you have enough paint & paint life extender to last until the next millennium..... Brillyant .........
    On a more serious note, if you buy metallic paints in a rattle can they don't immediately provide a gloss finish ...... You surface prepare, perhaps a little primer, flatten, spray on the metallic finish (X2 maybe) Then Lacquer X2 coats ..... Flatten the lacquer with 1500 grit or so, Then lacquer X2 again ...... Voilla soopah shiny colour coding ....... Whoa....... That & Tyre slick & that fine filly @ #42 will be waving at you from behind the net curtains like a biatch on heat .......
  7. #6
    Re: Refurb Wheels
    Quote Originally Posted by virtualm View Post
    echo that i used tins and they were all slightly different colour #fail so moral of the story is use the biggest tins you can or use a compressor and mix enough to do all the wheels with one mix !
    not to detract the how to JM well done !
    great write up
  8. #7
    Saab Afficionado Brennan's Avatar
    Join Date
    Jun 2012
    Location
    Northern Ireland
    Posts
    1,383
    Re: Refurb Wheels
    Great job, need mine done but think i'll leave it to the experts
    Former SAAB Driver
  9. #8
    Re: Refurb Wheels
    Bout £50 a corner round these parts at a shonky bodyshop
  10. #9
    Re: Refurb Wheels
    Quote Originally Posted by J..M View Post
    Nice job, but where have you seen new ones for £50?
  11. #10
    Re: Refurb Wheels
    Love the use of playing cards!
    great write up, am thinking of changing the colour of my wheels this winter...
    We do not stop playing because we grow old; We grow old because we stop playing.
  12. #11
    Re: Refurb Wheels
    Quote Originally Posted by plugger View Post
    he means wheel refurbs mate 50 a corner
  13. Remove Advertisements
  1. Turbo Refurb
    By jameswarlow in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 03-12-2011, 12:30 PM
  2. Alloy Refurb
    By Mull in forum Tyres, Wheels, and Brakes
    Last Post: 06-09-2010, 10:30 AM
  3. DI refurb?
    By saabanni in forum Saab 9000 (1984 - 1998)
    Last Post: 06-24-2009, 10:54 AM
  4. Wheel Refurb
    By petewill in forum Saab Recommendations
    Last Post: 05-30-2006, 09:37 AM
  5. Wheel refurb
    By Peterdon in forum Saab Recommendations
    Last Post: 12-14-2005, 12:39 PM
