2000 Saab 93 problems
Results 1 to 2 of 2
Thread: 2000 Saab 93 problems
  1. #1
    Question 2000 Saab 93 problems
    I have just purchased a 2000 93 convertible for the grand sum of £700
    The up side is its in great shape mechanically and body is excellent for year, leather seats great value and love driving it.
    The down side is there are a few niggles, many of which have been mentioned previously in older threads with links that no longet exist.
    Any help on the following would be great
    1 Wing mirrors not working, have checked fuse and OK, removed door switch and cleaned. What i need is a wiring diagram to test for voltage at the switch or someone to tell me what to check and how.
    2 Roof gets stuck when opening, the first part of the roof does not break, if i manually push it back to force it to break then it will go back and store correctly. I have topped up with fluid but not sure if needs more. I did pop into a roof specialist who mentioned something about "tension straps" and £400 to fix. I have WD40 all joins and had a good look all around but obvious faults. Any help much appreciated
    3 Intermittent starting, no obvious reason just will not turn over every now and then. Previous owner has a wire direct to starter that will get it going but is a real pain. Anyone know of a fix, there are lots of mentions of this fault but no permanent repair
    Just had the SID repaired and new areal fitted so can now tell what station is playing.
  2. Remove Advertisements
  3. #2
    Re: 2000 Saab 93 problems
    Moved from the 9-3 SS section to the section for the older model.
  4. Remove Advertisements
  1. SAAB 9-3 2.0 T. YR 2000. £900
    By adamwise in forum Previous model ranges, FOR SALE and WANTED
    Last Post: 07-21-2010, 03:06 AM
  2. Saab 9-3 2.0t SE, 2000, X
    By Kelvin in forum Previous model ranges, FOR SALE and WANTED
    Last Post: 01-20-2010, 07:35 AM
  3. 2000 Saab 9-3 Remote Central Locking Problems
    By pieeater in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 09-11-2008, 12:33 PM
  4. Saab 95 (2000)
    By chrisline90 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 07-18-2008, 12:32 PM
  5. Starting problems 9-3 2.2 TiD Y Reg 2000
    By hendylj in forum Help, Advice, Saabs and Motoring
    Last Post: 01-13-2008, 05:00 AM
