Smelly and damp air from air con
Results 1 to 8 of 8
Thread: Smelly and damp air from air con
  1. #1
    Saabisti
    Join Date
    Mar 2006
    Location
    Lancs, UK
    Posts
    214
    Help,
    After a week of running the air con, the air from the vents smells horrible and is very damp.
    I assume I have a blocked drain somewhere, can anyone point me in the right direction to be able to fix this?
    THANKS
    Richard
  2. Remove Advertisements
  3. #2
    Re: Smelly and damp air from air con
    It may also be the case that the air con system needs to be disinfected.
  4. #3
    ^^^What he said, you can get a can of a/c disinfectant from a good motor factor and DIY
    something like this: http://www.performancemotorcare.com/...t_Cleaner.html
  5. #4
    Not much point disinfecting if you don't look at and inspect the pollen filter, too. Best growth surface for microorganisms is a blocked filter or organic debris in the bottom of the filter housing. The main "aguarium" drain is in the centre at the front of the bulkhead behind the engine. You need to get the trim cover off the top of the space between the bulkhead behind the engine and the true bulkhead at the base of the windscreen and have a squint in to see if you have any water / gunk down in there unable to drain properly.
  6. #5
    Saabisti
    Join Date
    Mar 2006
    Location
    Lancs, UK
    Posts
    214
    Thanks for that, I will have a look this weekend, I think there must be a blocked drain as when we start ACC the air comes out smelly AND damp.
  7. #6
    Join Date
    Oct 2002
    Location
    Kippen, Stirling
    Posts
    2,673
    racingsnake,
    Smelly and damp air from the air vents can also be a sign of a leak in the heater matrix. Typically the smell has a slightly curry like odour. If it is more musty, like a wet tent then your back to the air con and pollen filter needing cleaned.
    Paul @ Kippen.
  8. #7
    Saabisti
    Join Date
    Mar 2006
    Location
    Lancs, UK
    Posts
    214
    Quote Originally Posted by paul anderson View Post
    racingsnake,
    Paul @ Kippen.
    Thanks Paul,
    yes it is VERY musty and dank air, I have had the curry smell with a duff heater matrix in the past with another car and this is a lot worse.
    Its finally stopped raining so I am going to investigate
    Cheers All
    Richard
  9. #8
    there is also a small drain (with rubber "non-return pipe") on the bottom of the evaporator case itself. I'm not sure how you'd get to it without removing the evap box though. I think you can get to peer into the box by taking off the sensor that sits on top nearest the fan (the bigger of the 2 black boxes on top of the casing). If the very worst happens, you can get to it all by taking the blower fan out - which isn't a fun job. Link at: http://www.saab9000.com/procedures/v...wer/blower.php
    I am still trying to chase down a funny smell in my 9000... Good luck!
  10. Remove Advertisements
  1. Smelly 9000
    By kprm77 in forum Saab 9000 (1984 - 1998)
    Last Post: 04-19-2008, 03:54 AM
  2. Loud and Smelly
    By richardf8 in forum Saab 9000 (1984 - 1998)
    Last Post: 09-18-2007, 02:24 PM
  3. Smelly air-con?
    By James in forum Help, Advice, Saabs and Motoring
    Last Post: 03-23-2005, 04:09 PM
  4. Smelly airco
    By Duplo in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 09-02-2003, 10:59 AM
  5. smelly air con
    By robert stephen dyer in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 04-27-2003, 03:46 AM
