Code:
DTC ..................................Malfunction Indicated
P0105 ................................. MAP Sensor; Faulty Operation
P0106 ..................................... MAP Sensor; Faulty Input
P0107 .................. MAP Sensor; Signal Low Or Shorted To Ground
P0108 ........ MAP Sensor; Signal High Or Shorted To Battery Voltage
P0110 ................................. IAT Sensor; Faulty Operation
P0112 ................... IAT Sensor Signal Low Or Shorted To Ground
P0113 .. IAT Sensor Signal High, Shorted To Battery Voltage, Or Open
P0115 ................................. ECT Sensor; Faulty Operation
P0117 ................... ECT Sensor Signal Low Or Shorted To Ground
P0118 .. ECT Sensor Signal High, Shorted To Battery Voltage, Or Open
P0120 .................................. TP Sensor; Faulty Operation
P0121 ...................................... TP Sensor; Faulty Input
P0122 .................... TP Sensor Signal Low Or Shorted To Ground
P0123 ... TP Sensor Signal High, Shorted To Battery Voltage, Or Open
P0125 ................................. CTS Sensor; Faulty Operation
P0130 ................................. Front HO2S; Faulty Operation
P0132 .. Front HO2S Signal High (Rich) Or Shorted To Battery Voltage
P0133 .................................... Front HO2S; Poor Response
P0135 .................... Front HO2S Heater; Current Outside Limits
P0136 ........................... Rear HO2S Heater; Faulty Operation
P0138 ......................... Rear HO2S Heater; Shorted To Voltage
P0140 .................. Rear HO2S Heater; Shorted To Ground Or Open
P0141 ..................... Rear HO2S Heater; Current Outside Limits
P0170 ............................................... Faulty Mixture
P0171 ................................................. Lean Mixture
P0172 ................................................. Rich Mixture
P0300 .............................................. Misfire; Random
P0301 .......................................... Misfire; Cyl. No. 1
P0302 .......................................... Misfire; Cyl. No. 2
P0303 .......................................... Misfire; Cyl. No. 3
P0304 .......................................... Misfire; Cyl. No. 4
P0327 ........................ Ignition Coil Module; No Knock Signal
P0335 .......................... CKP Sensor Signal; Faulty Operation
P0340 .......................... CPS Sensor Signal; Faulty Operation
P0441 ................................... EVAP Purge Valve; Low Flow
P0442 ..................................... Purge System; Small Leak
P0443 ............................ EVAP Valve Control Circuit Faulty
P0444 .. EVAP Valve Control Circuit Current Too High Or Open Circuit
P0445 ................... EVAP Valve Control Circuit Current Too Low Or Shorted To Ground
P0452 ................... Fuel Tank Pressure Sensor; Voltage Too Low
P0453 .................. Fuel Tank Pressure Sensor; Voltage Too High
P0455 ..................................... Purge System; Large Leak
P0500 ........................................ VSS; Faulty Operation
P0501 ................................... VSS; Signal Outside Limits
P0502 ............................................... VSS; No Signal
P0505 .................................. IAC Valve; Faulty Operation
P0506 ................................ IAC Valve; Idle Speed Too Low
P0605 ........................................... ECM Internal Fault
P1170 ..................................... Closed Loop; Malfunction
P1171 .................................... Closed Loop; Lean Mixture
P1172 .................................... Closed Loop; Rich Mixture
P1416 ............................................... Low Fuel Level
P1549 .......................... Boost Pressure Control; Malfunction
P1576 ......................... Brake Light Switch; Short To Voltage
P1577 ............................. Brake Light Switch; Open Circuit
P1611 ......................................... MIL; Short To Ground
