Bosch Super 4 for V6?
Results 1 to 5 of 5
Thread: Bosch Super 4 for V6?
  1. #1
    Banned
    Join Date
    Jul 2004
    Location
    Wooburn Moor
    Posts
    693
    I'm considering putting a set of Bosch Super 4 (FR78X I think) spark plugs in my newly-acquired V6 CSE. Does anyone have any experience - good or bad - of these in this engine? I'm attracted by the likely longevity, given the awkwardness of doing a plug change.
    BOF
  2. Remove Advertisements
  3. #2
    My advice would be to fit the plugs that saab advise due to the possibility of damaging the coil pack which can be expensive.Changing the plugs isn't that bad,its just unpluging and pulling out the way of the wiring harness that makes it a bit of a pain on the rear bank of three.At least you won't have to remove the inlet manifold as on the 2.5.Took me about an hour the first time but have just replaced the plug leads for which i also had to remove the intake pipe from the air filter to the inlet manifold and that still only took an hour.Any pics to post yet Dennis
  4. #3
    Saab Afficionado
    Join Date
    Feb 2005
    Location
    Isle of Wight
    Posts
    1,423
    I had some similar rather expensive plugs left when I changed an earlier 9K with a distributor for a newer one with DI. Put the new plugs in and the DI failed about 6 months later. Lesson learnt. You need the correct plugs which need to be resistance rated. If these are, then they might be OK.
  5. #4
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    NGK reckon that the iridium version of their plugs, apart from performing better, lasts around twice as long as the standard one, so I would go for those.
  6. #5
    Banned
    Join Date
    Jul 2004
    Location
    Wooburn Moor
    Posts
    693
    Thanks guys. Now that I've actually got the cover off the engine, I don't see what all the fuss was about - you're dead right, changing them is not going to be a problem.
    The handbook specifies Bosch FR8LDC plugs, so the FR78X should be OK. I STILL haven't made up my mind what to fit, though....
    BOF
  7. Remove Advertisements
  1. BOSCH HID kit on the bay
    By aeroadster in forum Help, Advice, Saabs and Motoring
    Last Post: 04-19-2007, 04:45 AM
  2. Bosch super 4 spark plugs
    By speedy in forum Saab 9000 (1984 - 1998)
    Last Post: 01-23-2005, 08:02 AM
  3. Bosch super 4 spark plugs
  4. Bosch or Lucas?
    By doktorevil in forum Classic Saab 900 (1979 - 1993)
    Last Post: 04-09-2003, 08:01 AM
  5. Bosch Alternators
    By ksowden1 in forum Saab 9000 (1984 - 1998)
    Last Post: 03-11-2002, 11:44 AM
