96 bonnet stuck shut
Results 1 to 9 of 9
Thread: 96 bonnet stuck shut
  1. #1
    Saab Afficionado robertson.a's Avatar
    Join Date
    Aug 2007
    Location
    Blackburn
    Posts
    1,590
    Hi all,
    How difficult is it to open the bonnet of a 9K when the cable pull doesn't do anything? I
    I am hoping the headlamps and grill don't need to be smashed off the car.
    I hear it is a VERY time consuming job.
    Any suggestions welcome, no matter how trivial.
  2. Remove Advertisements
  3. #2
    Saab Afficionado
    Join Date
    Feb 2005
    Location
    Isle of Wight
    Posts
    1,423
    No longer have a 9K but pretty sure that the cable runs just above the grill and you might be able to pull it through with some long nose pliers. Certainly you will not have to smash off the headlights, but could be some damage to the grill. Hopefully, someone that has had the same problem will soon come along and offer the best solution.
    ps If the cable is still intact and just the fasteners are stuck, perhaps try some gentle (bouncing type) pressure over the bonnet where the fasteners are, while someone else pulls the bonnet catch lever.
  4. #3
    Saabisti bilko's Avatar
    Join Date
    Oct 2007
    Location
    Ayr ,Scotland.
    Posts
    244
    Hi all,
    Any suggestions welcome, no matter how trivial.[/b]
    Hi Aus,if the bonnet pull still feels as if it has tension (ie:cable attached),but just not releasing the bonnet, try pulling the catch with your left hand while giving the top corner of the bonnet just below the windscreen a sharp blow with a clenched fist of your right hand ,hopefully this should let it pop up,Cheers,Bill.
  5. #4
    Motor Mouth
    Join Date
    Nov 2002
    Location
    Kent, England
    Posts
    2,041
    I can't remember exactly how but I did manage to get the grill off my '87 car by undoing the screws in the grill and filldling about a bit and without breaking anything - I got quite good at it as I used to solder the cable back together which would last for a while until it broke again. The grill on an '87 car is though deeper than later cars so not sure if the fixings are the same.
    Mike
  6. #5
    Saab Anorak
    Join Date
    Mar 2006
    Location
    Edinburgh
    Posts
    546
    Some have said it's possible to get at the bonnet catches by removing the front grille. Not easy, but there are 3 fixings along the top of the grille. You should be able to slip a torx 20? driver through between the rubber on the bonnet & the top of the grille. It might help if you can see where the 3 fixings are?... http://www.saabphotos.com/gallery/album615/bonnet
    Good luck
  7. #6
    Saabisti
    Join Date
    Dec 2006
    Location
    new jersey
    Posts
    200
    My 97 cse got stuck due to rubber stops being too low. The metal arrow shaped catch(on hood or bonnet) went beyond the spring loaded catch and caught the metal below it. I had to remove grill to see which direction to push bonnethood and pull release at same time... not fun KB
  8. #7
    Saab Afficionado serjeant's Avatar
    Join Date
    May 2003
    Location
    GWS Country
    Posts
    1,615
    Have you tried the two person method?
    Get someone to pull the handle while you attempt to 'lift' the bonnet.
    Sorry if this sounds obvious, but I alway try 'obvious' before opening the toolbox
  9. #8
    Join Date
    Oct 2002
    Location
    Kippen, Stirling
    Posts
    2,680
    aus715,
    I would describe the 2 person method rather differently than Naranto. I find the best way is to get the Assistant to press down as hard as they can on the front edge of the bonnet to releave the pressure on the catches while person 1 tries the lever. If the lever has broken use the pliers in the toolkit to pull the end of the cable.
    RULE No. 1 When you get it open lubricate the catches !
    If the cable is broken between lever and catches then revert to fiddling about with the plastic grill. If broken between catches then you will probably get the O/S one open giving enough leverage to get inside a bit more and perhaps get a grip on the broken cable.
    Replacing the cable is a bit of a pig. Best just to replace the inner and leave the outer in place rather than trying to fiddle it through the bulkhead etc. The catches are operated by little 'balls' grub screwed onto the end and adjacent to the O/S catch. Release these with an allen key and slip off the end. Feed the new ( scrappy ) inner through the outer from the cabin end and replace the 'balls'.
    Make sure you have lubricated the catches. I'm going to oil mine tonight. Reminder for everybody else.
    Paul @ Kippen.
    You only do this job once, it's such a pig. Lubricate NOW !
  10. #9
    Join Date
    Aug 2007
    Location
    Blackburn
    Posts
    1,590
    Thanks for all the excellent suggestions!!
    The bonnet was adjusted four months ago to fit better, after a kangaroo took out the offside wing, left wheel and headlamp. The paintshop never put it back well enough for my liking. Maybe I have created the problem and the bonnet catches are too tight. Here's hoping.
    I will try the two person method tonight, and try not to get too aggressive with the thing ( yet ).
    Will report back shortly.
    Thanks again for the advice.
  11. Remove Advertisements
  1. Igniton Barrel Stuck - Can't turn key - Stuck in reverse
    By Simonsinc in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 04-19-2011, 08:11 AM
  2. Help...my fan won't shut off
    By Honolulu4444 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 03-02-2010, 03:40 PM
  3. Bonnet wont shut properly
    By BertieBentnose in forum Saab 9000 (1984 - 1998)
    Last Post: 03-27-2007, 09:13 AM
  4. Help...my fan won't shut off
    By Honolulu4444 in forum Help, Advice, Saabs and Motoring
    Last Post: 12-31-1969, 08:00 PM
