Oil in throttle body
Results 1 to 3 of 3
Thread: Oil in throttle body
  1. #1
    Hi all.
    I have had my limp home activated, so I have bought a can of carb cleaner to get it back on the road quickly before arrangeing to remove and thoroughly clean the throttle body.
    However, when I removed the intake to the throttle body I noticed what looks like oil around the throttle body joint (where the plastic pipe and spiral worm clip go).
    Where would the oil come from?
    Should I be worried?
    What about the turbo?
  2. Remove Advertisements
  3. #2
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    The whole inlet tract downstream of the turbo will get a bit of oil. The crankcase vent system is sucked through the throttle body, either via the small pipe from the side of the throttle body (the one with the non-return valve on it under the engine cover) or through the pipe that comes over the engine and connects upstream of the turbo.
  4. #3
    Ah thanks.
    I was starting to get worried.
  5. Remove Advertisements
  1. CEL - Throttle Body?
    By pauljdh in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 06-19-2010, 06:14 PM
  2. Throttle Body
    By Jeff_bobik in forum Saab 9000 (1984 - 1998)
    Last Post: 04-15-2010, 12:51 PM
  3. Throttle body help
    By cortinadave in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 02-06-2009, 01:10 PM
  4. It wasn't the throttle body!
    By antonyn in forum Saab 9000 (1984 - 1998)
    Last Post: 06-18-2004, 12:03 PM
  5. Throttle Body
    By doopydug in forum Saab 9000 (1984 - 1998)
    Last Post: 05-30-2004, 07:35 PM
