Oil Vent ??
Results 1 to 3 of 3
Thread: Oil Vent ??
  1. #1
    Oil Vent ??
    After replacing the blower motor and Rheostat to fix the Aircon I took the oppertunity to change the DI unit as it had caused the car to run on three occasionaly.
    It made quite a difference as she feels a lot crisper and responsive.
    BUT I noticed that the Oil vent on the back of the rocker cover where the thick black hose from the right hand side of the engine and the small tube with the one way valve that comes from the throttle manifold, was broken off.
    Is this just pushed in or is there supposed to be a clip on the inside?
    I have ty-wrapped it in place for the moment but want to fix really.
  2. Remove Advertisements
  3. #2
    Re: Oil Vent ??
    You mean how does the plastic bit fit into the cam cover?
    It pushes into that rubber grommet. No other means of retention. The grommet is available separately and costs very little. A new one will probably be a much tighter fit than the original.
    www.saab9000.com - all you ever wanted to know about the Saab 9000
    www.saabits.com - stuff to help keep Saabs on the road
    Classic Saab 900 E-Code Headlamps
  4. #3
    Re: Oil Vent ??
    Yes I did mean how does it fit, i never paid attention to it until it was to late The rubber bit is still on it but it just falls out now.
    Right off to Cox of Ipswich tomorrow then
    Cheers mate
  5. Remove Advertisements
  1. Left vent is hot, centre vent is warm, right vent is cold?
    By speers in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 07-09-2011, 08:29 AM
  2. Need A New Air Vent
    By Hamish McSporran in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-27-2005, 06:13 PM
  3. Air vent
    By Xburn in forum Saabscene: Performance
    Last Post: 12-08-2003, 10:43 AM
  4. Air Con/Air Vent
    By Finlay in forum Saab 9000 (1984 - 1998)
    Last Post: 09-12-2000, 09:07 AM
  5. Air Con/Air Vent
