Panel Removal
NEWS
+ Reply to Thread
Results 1 to 6 of 6
Thread: Panel Removal
  1. #1
    Saab Anorak
    Join Date
    Feb 2003
    Location
    Fife,Scotland
    Posts
    765
    Panel Removal
    Trying to remove the insulation panel from under the drivers side dash, haynes say to use a small screwdriver to poke up the pin and then use a fork to release the fitting, I am having no luck whatsoever, can anyone help ??
    P.S. I am trying to pick up a ignition switched 12volt supply for my radar detector, any good locations ?, would prefer to have detector on my side of dash.
  2. Remove Advertisements
  3. #2
    Saab Anorak
    Join Date
    Jun 2002
    Location
    Bologna (Italy)
    Posts
    623
    Re: Panel Removal
    Why doesn't the cigarette lighter works for you? It's under key, and easyly accessible.
    Anyway, when I have to remove my kickpanel, I turn out the screws without putting too much pressure on it, and then pull out the pins, they can come only if the screw is removed or loosened at least. When you'll have removed them it will be obvious how they works.
    Let know.
  4. #3
    Turbo Talker
    Join Date
    Feb 2002
    Location
    linlithgow
    Posts
    4,215
    Re: Panel Removal
    emmm...as haynes describes it sound simple but...
    the screwdriver needs to be small (jewlers type) and you push till the resistance goes (all of a sudden !!)
    This will allow you to prise the big flat bit off with a fork,bigger screwdriver etc
    BEWARE the prongs on the this fixing can be fragile and ,if snapped off,will damn you forever to have a loose and shoogly panels like mine
  5. #4
    Re: Panel Removal
    Having damned two of my cars similarly, I found Halfords sells similar trim clips with a centre-pin that pushes in but can be unscrewed again with a screwdriver. The usual rip-off price of a few quid for a pack of 5 or so, but they do the job and are less likely to need to be replaced in the future.
    www.saab9000.com - all you ever wanted to know about the Saab 9000
    www.saabits.com - stuff to help keep Saabs on the road
  6. #5
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Re: Panel Removal
    You can also re-use the existing caps if you lose the centre pin by screwing in a self tapping screw (no 6 or 8, can't remember )
  7. #6
    Saab Anorak
    Join Date
    Feb 2003
    Location
    Fife,Scotland
    Posts
    765
    Re: Panel Removal
    Thanks all, had given up hope on this 1 but as usual the forum comes up trumphs
  8. Remove Advertisements
+ Reply to Thread
  1. Plastic Panel removal
    By jedd in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 10-20-2010, 08:00 AM
  2. ACC Panel Removal
    By raboni in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 09-29-2009, 06:38 AM
  3. Removal of knee panel
    By Honeyman in forum Classic Saab 900 (1979 - 1993)
    Last Post: 04-20-2007, 01:58 AM
  4. Panel Removal
    By HAGGAG01 in forum Saab 9000 (1984 - 1998)
    Last Post: 03-18-2003, 12:25 PM
  5. Plastic Panel removal
    By Jedd in forum Help, Advice, Saabs and Motoring
    Last Post: 12-31-1969, 07:00 PM
