Tips on getting the plastic covers off the underside...
NEWS
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 29
Thread: Tips on getting the plastic covers off the underside...
  1. #1
    ... and getting them back on again?
    On both my '96 Aero and '96 CSE, the bolts that hold the plastic panels on under the front of the car are largely rusted to their captive threaded inserts, except that after a bit of turning effort, the inserts are no longer captive!
    To get the LH wheel arch liner off the Aero and the RH liner off the CSE, I had to cut the very front bolt that hods three panels together. I can live without this one. However, on both cars I was unable to remove the cover under the radiator to access the drain plug. Again, no problem as I removed the hose from the water pump instead and pointed it downwards to drain the radiator.
    However, I am shortly to replace the front bumper on the CSE and from what I can see, I will need to remove the front underside cover. Any tips on removing this (the bolts are only accessible from underneath) and on how to re-attach it? Are there any fixings that I can fit that won't rust up again? Are these things available from a Saab dealer?
    I haven't even looked at the situation on the '95 yet, and expect it to be just as bad...
    www.saab9000.com - all you ever wanted to know about the Saab 9000
    www.saabits.com - stuff to help keep Saabs on the road
  2. Remove Advertisements
  3. #2
    Saab Anorak
    Join Date
    Dec 2001
    Location
    Croydon, Surrey, UK
    Posts
    763
    Re: Tips on getting the plastic covers off the underside...
    These fixings are available from SAAB, at a cost! but also available from reputable fixing manufacturers like 'Infast' who were based in Croydon at one time. I managed to get a whole box of these bolts/mushroom nuts which fit these plastic trays quite cheaply from them years ago....and can't find it now . also, for my old 900 T head gasket replacement, I got a set of cyl head bolts from them at a fraction of the SAAB cost! 'Infast' is still around somewhere...maybe worth a search on the net.
  4. #3
    Saab Anorak
    Join Date
    Dec 2001
    Location
    Croydon, Surrey, UK
    Posts
    763
    Infast Branches all over UK:
    www.infast.com/industrial/ukbranches.html
  5. #4
    Thanks, mutungi.
    Is that what they're called: "mushroom nuts"? I don't suppose you know what the spec. is? I'm sure I can work out the spec. of the bolt but are the nuts specified for a particular thickness of material, for example?
    No chance they are available with a stainless steel thread, I suppose... ?
  6. #5
    Saab Nut
    Join Date
    Aug 2001
    Location
    Romsey, Hampshire UK
    Posts
    360
    One of the electronics catalogue firms - RS or Farnell (can't remember which one) shows captive nuts in the "fasteners" section which appear to be identical to the SAAB ones. I'm tempted to get some and try nylon bolts. (The hoses on my washer bottle keep coming off so I've had the panels off [well, bent back really cos of the stuck bolts)umpteen times).
    Try http://www.farnell.com - accepts credit card orders from anybody
    or http://rswww.com - has "trade" counters round the country
  7. #6
    Thanks, Mike.
    Being in the electronics industry, I'm familiar with both of these, so I'll have a look. Don't know why I didn't check them before.
    For the record, I couldn't find anything like these on the ScrewFix website.
  8. #7
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Bill,
    Have had much the same problems on my MY93- believe me it gets worse with age!!!
    The tray, however is not so bad as much of the rest of it. The main "bolts" that are to the rear of it are in actual fact self-tapping threads that screw into plastic inserts in the sub frame, so no worries there. As regards the rest of it, I've just used stainless steel self tappers with large washers to fix things back together- much easier!
    If you're removing the bumper, then taking the front spoiler off may prove difficult. Amongst the bigger stuff, it's fixed by some smallish (circa M4) bolts to the bumper just above the bottom air scoop. They DO rust to buggery and very often prove difficult to get out without basically yanking the damn thing off. I managed to replace those though once exposed by chopping their rusted heads off with a stout pair of cutters.
    And my tip for holding the three sections together at the front outside corners of wheel arches is cables ties- not very elegant but quiet straightforward to fix and cheap.
    Good luck!!
    Mark
  9. #8
    Motor Mouth
    Join Date
    Jun 2000
    Location
    Preston UK
    Posts
    2,599
    Bill,
    This is one of the worst aspects of Saabs - the cheap fasteners they use on the undertrays. Derek was the amn who got the larger captive nuts (jacknuts) M8 from RS (stainless) and sent me some. I then simply fitted new bolts (dont use Saab far too expensive) with plenty of copperslip. The ones holding the front of the spoiler to the bumber on the CSE (not sure about the Aero as looking at piccies is seems to have a two piece spoiler) are M4 jacknuts.
    Have fun
  10. #9
    Thanks, Adrian.
    I ordered 50 M6 jacknuts today from RS, along with 100 screws and washers. I didn't order M8 as I want them all to be the same (I can simply fit stainless screws and washers to replace the ones that haven't siezed yet).
    Perhaps I should have got the M4 ones for the bumper too, but I'll cross that bridge when I come to it. The new (second-hand) bumper doesn't appear to be missing any and there aren't any broken screws in them, so perhaps all I need are new screws.
  11. #10
    Saabisti
    Join Date
    Jan 2002
    Location
    Riga, Latvia
    Posts
    126
    Ohhh... theese M4 f..ked me up a bit last weekend. As I went on the ramp to fasten the things there a bit after major repair (they had removed those plastics, but poorly fastened them back). And those M4 had 7mm (non-standard) heads, damn... , and I have to drive them by pliers.
  12. #11
    Well, lucky I have a 7mm socket.
    Do you happen to know how long the M4 screws are? I think I'll get some in stainless and some Jacknuts, just as a matter of course. I suppose they need to be long enough to set the Jacknuts with.
  13. #12
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    The M4's are approx 20-25mm including heads. You'll need one about 30mm to compress the fitting unless you can scrounge the natty tool that does it for you...
    And you're right to get the nuts as well- remember you can't see whether they've rusted up and won't know until you try losening them and the whole thing turns!!
    Mark
  14. #13
    Thanks, Mark. I'll get some 20mm ones (I'm pretty sure that refers to the threaded part without the head). I have a couple of longer ones to compress the nuts if necessary. The 20mm ones should be long enough to compress the short M4 Jacknut, though.
  15. #14
    Did all the M6 ones tonight. I was doing well and replaced all the screws in the wheel arch and got the undertray off complete (middle and both ends) when the heavens opened with a thunderstorm (my garage isn't big enough to have the car in it and work on it as well, and I don't have any light either). So I took the tray and worked on it, removing the old nuts and fitting new ones. I ended up poking the front of the car into the garage, but didn't have room to jack it up in there and it took quite a while, especially as it was getting dark and I had to use the headlamps.
    I'm very pleased to get it done. I've never seen under that part of a 9000 without the undertray before. I'll do the other cars in the near future when I have more time.
    I'll have to revisit one of them, though, as I managed to cross-thread it and it doesn't take much to break those nuts free...
    I should be getting the M4 ones tomorrow, but at least now I know what I'm doing.
    Thanks for all the suggestions. I'd have been out an awful lot of money if I'd gone the dealer route.
    For future reference, RS accept credit card payment and you don't need an account any more. The part numbers are:
    288-3071 £14.40 Insert, threaded, jacknut, short, M6 (pack of 50)
    527-404 £4.04 Washer, plain, stainless steel, M6 (pack of 250)
    520-144 £7.22 Screw, set, hexagon head, stainless steel, M6 (pack of 100)
    288-3100 £11.23 Insert, threaded, jacknut,
    short, M4 (pack of 50)
    527-381 £2.83 Washer, plain, stainless
    steel, M4 (pack of 250)
    520-037 £5.55 Screw, set, hexagon head,
    stainless steel, M4 (pack of 100)
    OK, I spent quite a bit, but there should be enough there for all three cars, and I do need to remove the front spoiler from the Aero to fill and paint over the "kerb-rash".
  16. #15
    Saab Newbie
    Join Date
    Aug 2002
    Location
    Cumbria
    Posts
    6
    Cook nuts with torch (carefully) this melts plastic roung them and panels may be removed. replace with large head/thread self tappers in new holes. - simple but effective if appearance is not a worry.
  17. Remove Advertisements
+ Reply to Thread
  1. Nut And Bolts To Secure Underside of Wings?
    By kaner1979 in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 05-05-2010, 10:11 AM
  2. Tips on 900
    By rparker in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 06-01-2006, 03:24 AM
  3. Tips on getting the plastic covers off the underside...
    By billj in forum Saab 9000 (1984 - 1998)
    Last Post: 08-21-2005, 10:40 PM
  4. wet underside boot lid
    By wbhollmann in forum Classic Saab 900 (1979 - 1993)
    Last Post: 03-04-2004, 04:06 AM
  5. top tips - oh no..
    By rhino2.3t in forum Saab 9000 (1984 - 1998)
    Last Post: 12-19-2003, 09:50 AM
