And now, how to cure the "hiccup" at high boost?
NEWS
+ Reply to Thread
Results 1 to 14 of 14
Thread: And now, how to cure the "hiccup" at high boost?
  1. #1
    Saab Anorak
    Join Date
    Dec 2001
    Location
    Croydon, Surrey, UK
    Posts
    763
    When accelerating uphill, at kickdown or at sudden acceleration at high speed on motorway to increase speed, the car "hiccups" (cuts-out) and resumes normally if you release the gas. Have tried new DI unit, new NGK's gapped at 1.0mm but problem still there!
  2. Remove Advertisements
  3. #2
    Saab Nut
    Join Date
    Sep 2000
    Location
    Gloucester, UK
    Posts
    260
    Re: And now, how to cure the "hiccup" at high boost?
    Ooh! Sounds like the overboost protection is coming in.
    What boost levels are you running?
    Pete.
  4. #3
    Saab Nut
    Join Date
    Dec 2001
    Location
    FL370 or in a SAAB
    Posts
    267
    Had a similar problem once on a 2.0LPT Bosch LH Saab DI system, turned out to be the Inlet Air Temp sensor (half way up the inlet trunking)
  5. #4
    Saab Anorak
    Join Date
    Dec 2001
    Location
    Croydon, Surrey, UK
    Posts
    763
    Boost levels? Default from factory....I have not adjusted anything....this is a LPT...can it be adjusted? How do you check/determine the boost levels?
    Inlet ait temp sensor? Is this the brass plug screwed in the inlet manifold with the black wiring harness?
  6. #5
    Saab Junior
    Join Date
    Dec 2001
    Location
    Sheffield UK
    Posts
    27
    Check the waste gate operation rod hasnt corroded through and stuck open. Took me ages to find on mine !!!!!. It gave identical symptoms!
    Matt
  7. #6
    Saab Anorak
    Join Date
    Dec 2001
    Location
    Croydon, Surrey, UK
    Posts
    763
    Well.....gave it the true test on the way to and back from Wales yesterday, afraid it "hiccups" with sudden acceleration when overtaking or going uphill when more power is required....no "hiccups" when you increase speed gently. Plugs set at 1.00mm (NGK's), all hoses,etc Ok......is there a boost protection somewhere which is set low, etc. or ....???
  8. #7
    Saab Afficionado
    Join Date
    Sep 2001
    Location
    Norwich, Norfolk
    Posts
    1,925
    Definately sounds like overboost protection working. I take it yours is FPT if so watch your boost gauge and see where it's getting to when it cuts out. It should get into the red, 1/3 to 1/2 way, before cutting the fuel.
    Neil
  9. #8
    Saab Anorak
    Join Date
    Dec 2001
    Location
    Croydon, Surrey, UK
    Posts
    763
    No...not FPT but LPT with no dash gauge....also when set to cruise...hiccups like mad every time it needs to boost to maintain set speed, then have to get it off cruise to drive normal.
  10. #9
    Saab Anorak
    Join Date
    Nov 2001
    Location
    Stirling, Scotland,U.K.
    Posts
    507
    muntungi. I have an identical problem with my '93 LPT when I run it on LPG from cold.( It's duel fuel) I've noticed that this seems to be acompanied by a hissing sound during the misfire.I've wondered if this is an overboost problem but know nothing about how this works,Is it as sudden as this when the protection cuts in? It's a sudden loss of power which isn't restored until you back of the throttle.
  11. #10
    Saab Anorak
    Join Date
    Nov 2001
    Location
    Posts
    507
  12. #11
    Saab Afficionado
    Join Date
    Sep 2001
    Location
    Norwich, Norfolk
    Posts
    1,925
    Have you checked to see if your waste gate is working? If not this can cause the overboost problem. I had this problem on my FPT, the wastegate was seized. Took the turbo off and cleaned it and it seems to have been ok since.
    HTH
    Neil
  13. #12
    Saab Anorak
    Join Date
    Dec 2001
    Location
    Croydon, Surrey, UK
    Posts
    763
    Neil...how do I check the wastegate on the turbo? Where is it? BTW this is LPT....same turbo as FPT?
  14. #13
    Saab Afficionado
    Join Date
    Sep 2001
    Location
    Norwich, Norfolk
    Posts
    1,925
    The turbo is different, but should be the same setup. Do this when the engine is cold. Reach down behind the exhaust turbine side of the turbo unit, you should find a rod coming out of a silver cylinder, and attached to a lever at the other end(left looking from front of car), this is the wastegate rod. Although it could be quite stiff, you should be able to move this rod. This action opens and closes the wastegate in the turbo. the only way i could move mine initially was with a large lever bar. If you can't budge it at all, it could well be seized up with soot.
    If it is seized try to get some WD40, or similar, into the lever sleeve and work the lever, you can disconnect the rod by removing the "R" clip and pulling it off.
    Bit long winded but hope you understand it.
    Neil
  15. #14
    Saab Afficionado
    Join Date
    Apr 2002
    Location
    Coventry, UK.
    Posts
    1,908
    If you can determine that the wastegate is OK, then maybe the previous owner had the boost wound up on the turbo (i.e. a bit too much) by adjusting the linkage between the actuator and the wastegate. This is easily done (if it isn't rusted) and would still make the car seem standard by all appearances.
    The ECU on the 2L LPT limits boost to around 0.6 bar, so it is easy to reach overboost if any linkage adjustment occurs.
    Alternatively the actuator may have failed, but they are extremely robust, and this is unlikely.
    I have found that significant soot build up in the wastegate is hard to clear with Plus Gas/WD40, and a strip down and clean of the wastegate part of the Turbo may be required. Cost me £50 by a local garage on one occassion, although sevveral Turbo specialists tried to sell me a new Turbo, including the main dealer in Cardiff!
  16. Remove Advertisements
+ Reply to Thread
  1. boost pressure control valve "blow" test
    By saabanni in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-27-2010, 01:50 PM
  2. Replies: 0
    Last Post: 01-05-2006, 01:00 AM
  3. "Yes" another boost question again
    By Steve-Stage 2 in forum Saabscene: Performance
    Last Post: 08-04-2005, 07:10 PM
  4. "Front Strut brace" = "Understeer" ?
    By Aeroadster in forum Saabscene: Performance
    Last Post: 11-02-2004, 07:30 AM
  5. And now, how to cure the "hiccup" at high boost?
    By mutungi in forum Saab 9000 (1984 - 1998)
    Last Post: 06-10-2002, 06:09 AM
