1.8t or 2.0t
NEWS
+ Reply to Thread
Results 1 to 11 of 11
Thread: 1.8t or 2.0t
  1. #1
    Saab Newbie
    Join Date
    Mar 2003
    Location
    Toronto
    Posts
    3
    1.8t or 2.0t
    For Europeans there is an entry level version available with 150HP named 1.8t. The engine is still 2lt, same as that of the U.S. Linear but the turbo is set to 0.5 bar (175 HP is 0.7 bar, I think).
    Has anybody driven the 1.8t? Is there a big difference than the 2.0t.
    Is there a way to chip the 1.8t and get, say, 190 HP, spending something like 500e?
    Any other differences between the 1.8t and the 2.0t (i.e. brakes, gearing etc.)?
    Where can I find tecnical specs for the cars?
  2. Remove Advertisements
  3. #2
    Turbo Talker
    Join Date
    Feb 2002
    Location
    linlithgow
    Posts
    4,215
    Re: 1.8t or 2.0t
    welcome to the board...
    I have the 1.8t and i find the power adequate although you do have to rev it a bit more than I am use to to get it moving
    I have also heard that there is little difference between the 1.8 and the 2.0
    I believe the 1.8t and the 2.0t is identical in every way apart from the mapping in the ecu (and a boost gauge ) but I could be mistaken
    I also believe that it would only take a re-map to increase the power ..everything else is the same.
    When I get the car serviced (who knows when !!)
    i will try the waters to see whether I can blag an upgrade (the saab dealer owes me big time )
    I have not heard of a third party offering this (yet !!)
    the specs of the suspension is down to the trim level ie arc or vector and not the engine size (aero excepted !!)
  4. #3
    Mega Motor Mouth
    Join Date
    Nov 2001
    Location
    Europe
    Posts
    3,618
    Re: 1.8t or 2.0t
    Specifications is it?
    Max. power:
    1.8t - 150bhp (110KW) - @ 5,500 rpm
    2.0t - 175bhp (129KW) - @ 5,500 rpm
    2.0T - 210bhp (155 KW) - @ 5,300 rpm
    2.2TiD - 125bhp (92 KW) - @ 4,000 rpm
    Max. torque:
    1.8t- 240Nm @ 2,000 rpm
    2.0t - 265Nm @ 2,500 rpm
    2.0T - 300Nm @ 2,500 rpm
    2.2TiD - 280Nm@ 1,500-3,000 rpm
    Bore/stroke:
    1.8t - 86 mm x 86 mm
    2.0t - 86 mm x 86 mm
    2.0T - 86 mm x 86 mm
    2.2TiD - 84 mm x 98 mm
    Compression Ratio:
    1.8t - 9.5:1
    2.0t - 9.5:1
    2.0T - 9.5:1
    2.2TiD - 18.5:1
    Max. boost pressure:
    1.8t - 0.50 bar
    2.0t - 0.70 bar
    2.0T - 0.85 bar
    2.2TiD - 1.00 bar
    Ignition/
    Fuel injection:
    All petrol:
    Saab Trionic 8 engine management.
    Direct ignition. Multi-point fuel injection.
    All Diesel:
    Bosch. Multi-point fuel injection.
    Performance :
    0-100 km/h (s)
    1.8t - M5 9,5
    1.8t - A5 10,7
    2.0t - M5 8,5
    2.0t - A5 9,7
    2.0T - M6 7,9
    2.0T - A5 8,8
    2.2TiD - M5 11,0
    60-80 km/h 4th gear (s)
    1.8t - M5 10,0
    2.0t - M5 8,5
    2.0T - M6 7,5
    2.2TiD - M5 8,0
    80-120 km/h 5th gear (s)
    1.8t - M5 14,0
    2.0t - M5 12,5
    2.0T - M6 10,5
    2.2TiD -M5 12,5
    Top speed km/h
    1.8t - M5 210
    1.8t - A5 210
    2.0t - M5 225
    2.0t - A5 220
    2.0T - M6 235
    2.0T- A5 230
    2.2TiD - M5 200
  5. #4
    Saab Newbie
    Join Date
    Mar 2003
    Location
    Toronto
    Posts
    3
    Re: 1.8t or 2.0t
    I also need the f/r brake diameter and gearing info.
  6. #5
    Saab Fan
    Join Date
    Dec 2002
    Location
    The Promised Land
    Posts
    68
    Re: 1.8t or 2.0t
    Blimey, that 2.0T has a lot of torque doesn't it!!
  7. #6
    Mega Motor Mouth
    Join Date
    Nov 2001
    Location
    Europe
    Posts
    3,618
    Re: 1.8t or 2.0t
    Brakes .
    Hydraulic, dual circuit, vacuum booster. ABS,TCS, mech. brake assist.
    Brake disk sizes.
    1.8t - 283mm, ventilated steel (front)
    2.0t - 300 mm, ventilated steel (front)
    2.0T - 312 mm, ventilated steel (front)
    2.2TiD - 300 mm, ventilated steel (front)
    1.8t - 276mm, solid steel (rear)
    2.0t - 276mm, , solid steel (rear)
    2.0 T - 290 mm, solid steel (rear)
    2.2TiD - 276mm, , solid steel (rear)
    Vehicle Speed attained at an engine speed of 1000rpm.
    Manual Petrol (km/h)
    1st - 8.3-8.6
    2nd - 16.0-16.5.
    3rd - 23.8 - 24.6.
    4th - 31.5-32.5
    5th - 42.6-44.0
    Reverse - 8.9-9.2
    Manual Diesel (km/h)
    1st - 8.3-8.6
    2nd - 15.9 - 16.4
    3rd - 25.3 - 26.1
    4th - 33.4 - 34.5
    5th - 45.2 - 46.6
    Reverse - 8.7 - 9.0
    Automatic (km/h)
    1st - 10.0 - 10.4
    2nd - 15.4 - 15.9
    3rd - 23.5 - 24.3
    4th - 34.8 - 35.9
    5th - 45.8 - 47.4
    Reverse - 9.1 - 9.4
  8. #7
    Turbo Talker
    Join Date
    Feb 2002
    Location
    linlithgow
    Posts
    4,215
    Re: 1.8t or 2.0t
    mark a..
    my manual says ..
    brake disc front 1.8t/2.0t/2.2tdi...285 mm
    rear.....................278 mm
    2.0T front ...................314
    rear.....................294
  9. #8
    Mega Motor Mouth
    Join Date
    Nov 2001
    Location
    Europe
    Posts
    3,618
    Re: 1.8t or 2.0t
    Ylee, your data is probably correct.. the data I have is marketing data
  10. #9
    Saab Nut
    Join Date
    Oct 2001
    Location
    Aberdeen
    Posts
    477
    Re: 1.8t or 2.0t
    Ylee, Abbott are already offering ECU upgrades. They had a 220 BHP version available 2 months before the Aero was launched. Not sure which model this was based on though?
    Neil
  11. #10
    Mega Motor Mouth
    Join Date
    Nov 2001
    Location
    Europe
    Posts
    3,618
    Re: 1.8t or 2.0t
    220hp version based upon 2.0t (175hp).. I'm assuming that it will also work on 150hp version too... why shouldn't it?
  12. #11
    Saab Newbie
    Join Date
    Mar 2003
    Location
    Greek living in Belgium
    Posts
    23
    Re: 1.8t or 2.0t
    *[/b]
    The rear disks on the 2.0T are ventilated
    1st - 8.3-8.6
    2nd - 16.0-16.5.
    3rd - 23.8 - 24.6.
    4th - 31.5-32.5
    5th - 42.6-44.0
    Reverse - 8.9-9.2[/b]
    When I test drove the aero,I did that test with the 6th gear.I got more than 55km/h on 1000rpm.
    Not bad e?
    But I think that 6th is a gear for the highways and the engine can't go more than 4000-4500rpm with it.(overdrive?not sure if this is the correct word).
    Can anybody who has an aero confirm it?I was too excited during the test drive and I could be wrong
  13. Remove Advertisements
+ Reply to Thread
