Buzzing from behind the dash
+ Reply to Thread
Results 1 to 10 of 10
Thread: Buzzing from behind the dash
  1. #1
    Saab Newbie
    Join Date
    Jan 2004
    Location
    HULL ENGLAND
    Posts
    14
    On my 2001 9-3 I have an annoying issue when I turn the ignition off. There seems to be a buzzing from behind the dash which takes about 10 mins to stop.
    I never had the problem with my old Saab but that never had ACC, which I am presuming is the issue.
    Any ideas?
  2. #2
    Re: Buzzing from behind the dash
    This rings a bell. Hmmm...
    Does this resemble it? 'Dashboard poltergeist':
    http://www.saabscene.co.uk/ubb/ultimatebb....394.html#000000
  3. #3
    Saabisti
    Join Date
    Jul 2004
    Location
    ilkeston/derbyshire
    Posts
    227
    There is also problems with the ACC dash temp sensor, located in one of the switch blank positions.
    It may be worth removing sensor, remove ACC panel and sensor comes out from behind, give it a good glean and some wd40.
    HTH
  4. #4
    Hull Saab
    May be related to your problem
    This sounds like a something that I have on my 2000 9-5 2.0 lpt.
    If you turn the ignition off after a run you get a strange buzzing noise from behind the drivers side dash that usualy lasts for a few minuites, and then slowly fades away(it sounds electrical), but you only get this noise after using the air-con.
    If you dont use the air-con during a trip.....you don't get the noise after
    I decided to live with it as the car hasn't set itself on fire yet but I would love to know whats causing it.
  5. #5
    Saab Newbie
    Join Date
    Oct 2004
    Location
    bristol
    Posts
    20
    Yes. I drove a 93 FPT where the noise was very pronounced. I get the same buzzing (I thought it was from the passenger side -definitely the centre consol ) only much quieter on my 93SE
  6. #6
    Saabisti
    Join Date
    May 2004
    Location
    Nottingham
    Posts
    101
    Is the buzzing definitely in the dash?
    I've got a 1999 2.2 TiD. When I switch my engine off I get a quiet buzzing noise, which I thought was in the dash, but have now traced to the electrics on the side of the ABS block, under the bonnet behind the battery.
    It buzzes (or very fast clicking sound) for about 20 seconds after switching off, then a relay clicks and it stops.
    I don't know if it is supposed to do this? (Anyone know?). But I've never had a warning light or message so I've been ignoring it!..
  7. #7
    Saab Newbie
    Join Date
    Apr 2004
    Location
    Albrighton, UK
    Posts
    14
    I get the same buzzing noise from the centre console of my car (Saab 9-3 SE 1998 2.0i with ACC). It seems to be there all the time the engines running (although you can't really hear it 'cause of the engine) and continues for about 10 mins after switching off. If you put your hand over the ACC sensor in the dash it gets quieter - so I just presumed it's some sort of sensor/fan thing and is normal.
    Is it normal??
  8. #8
    Saabisti
    Join Date
    Jul 2003
    Location
    Wales, UK
    Posts
    182
    It is the sensor being discussed and a few months ago mine got to the point where it became audible even whilst driving.
    I thought the fan within the sensor itself had gone noisy so I decided to remove it for a clean up/oiling.
    Getting to it means taking the glove box out to take the footwell panel out. It's not as bad as it sounds; it's about a ten minute job.
    Anyway, the fan itself was fine, the sensor body was rattling against the front fascia panel (it's only a push fit) because the isolation gasket was no longer doing its job.
    As my nearest SAAB dealer is a two hour drive away, I made a new gasket out of a bit of corrugated carboard from an old packing box and used this along with the old gasket to make the fit nice and tight again.
    I can now barely hear the sensor and it's even quieter than when I first brought the car, and for the first few days after this job I was paranoid about whether or not it was still working!
  9. #9
    Saabisti
    Join Date
    Aug 2003
    Location
    Washington DC Metro area
    Posts
    134
    Any chance it could be the spark plugs burning off deposits? Supposedly unique to SAAB is that after the ignition is turned off..the plugs get one last charge from the cassette to burn off residue...
    just a thought.
    dc
  10. #10
    Saab Newbie
    Join Date
    Apr 2004
    Location
    Albrighton, UK
    Posts
    14
    I took the sensor out, cleaned all the fluff off it, a few sprays with WD40 and, hey Presto, no more buzzing. Only a slight hum when you put your ear next to it.
    It takes longer to remove the glovebox and kick panel than to 'service' the sensor!
    When I re-installed it I reversed the gasket so it was a tight fit.
    Also got the glovebox light working again in the process.
  11. Remove Advertisements
+ Reply to Thread
  1. 9.3 2.2TiD Buzzing noise from behind dash
    By bluebard2 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 10-09-2010, 03:07 PM
  2. 9k aero, Buzzing from lefthand side of the dash.
    By bobphotographer in forum Saab 9000 (1984 - 1998)
    Last Post: 10-25-2006, 07:39 PM
  3. Buzzing from behind dash when engine stops
    By mickheduan1 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 10-07-2005, 06:57 AM
  4. Buzzing Sounds From the Dash... and Speedo Issues
    By BurnsSide42 in forum Saab 9000 (1984 - 1998)
    Last Post: 11-11-2003, 07:26 AM
  5. Buzzing Sounds From the Dash... and Speedo Issues
