A/C Not working on '97 Saab 900 SE Torbo
NEWS
+ Reply to Thread
Results 1 to 2 of 2
Thread: A/C Not working on '97 Saab 900 SE Torbo
  1. #1
    My A/c stopped working. I've gone through all of the checks in the owners manual, and did not find a problem. Curiously the ambient temperature gauge is reading about 9 degrees higher than actual. Has anyone experienced this problem? I suspect this may be a coincidence. Is my problem likely to be coolant loss or a malfunction in the compressor clutch?
    Tomlon
  2. Remove Advertisements
  3. #2
    Motor Mouth
    Join Date
    Nov 2002
    Location
    Kent, England
    Posts
    2,041
    Re: A/C Not working on '97 Saab 900 SE Torbo
    Hi Tomlon
    Welcome to Saabscene - probably worth getting the A/C gas checked first especially if it has not been done for some time. There is a pressure switch in the system which cuts off the A/C altogether if the gas pressure has dropped. If there is a leak it can detected by dye in the system when tested. If pure A/C rather than climate control then I don't think the ambient temp is relevant unless about 2 degrees C or freezing when the A/C cuts off.(Can't remember exactly at what point) Others may know more - clutch problems usually present as slippage first and intermittent/poor A/C - Can you hear the clutch clicking in or out at all? Try a search here as adjusting the clutch has been discussed before. This topic may benefit more by being moved to the GM900/9-3 forum where others may view - admin - can you help with this?
    Mike
  4. Remove Advertisements
+ Reply to Thread
  1. Nearside full beam, working, then not working
    By peelaaa in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 02-22-2010, 09:54 AM
  2. Saab 93 Brakes not working?
    By Harpal in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 11-21-2008, 04:50 AM
  3. Replies: 0
    Last Post: 10-15-2007, 06:14 AM
  4. Noisy Torbo? Induction? or Dump valve?
    By Pete A in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 08-21-2004, 06:25 PM
  5. Saab 93 Brakes not working?
    By Harpal in forum Help, Advice, Saabs and Motoring
    Last Post: 12-31-1969, 07:00 PM
