Electric window track repair
NEWS
+ Reply to Thread
Results 1 to 5 of 5
Thread: Electric window track repair
  1. #1
    Saab Newbie
    Join Date
    Apr 2004
    Location
    Houston, Texas
    Posts
    3
    Any tips or suggestions for drivers window that came off its track in a 1999 9-5?
    Door skin removal tips?
    Any hidden screws bolts or clips to look for?
    Thanks in advance, Brent
  2. Remove Advertisements
  3. #2
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    Re: Electric window track repair
    There are screws in the door handle and the pull handle. I think you have to lever up the window trim and prise out the boot and filler release buttons. Then the trim comes off like all the others over the years. But you need to be careful with the waterproof membrane. There's so much electrical stuff in the door, including the impact sensor, that you have to keep things dry.
    Oh yes - Welcome to Saabscene!!
  4. #3
    Saab Newbie
    Join Date
    Apr 2004
    Location
    Houston, Texas
    Posts
    3
    Thanks for the tips I am also wondering how the window attaches to the track and why it just came off!?!? Thanks for your help. I was unaware of the impact sensors. What happens if the sensors are triggered?
    Brent
  5. #4
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    The side airbag goes off!!
    Turn off ignition and leave it all alone for about half an hour for any electronics to discharge.
  6. #5
    Saab Junior
    Join Date
    Sep 2003
    Location
    birmingham UK
    Posts
    34
    After having my 9-5 just one month I lowered the window and there was an almighty bang. I tried to lift the window it then dropped into the door. The bang was one of the plastic pulleys supporting the window breaking. It was repaired under warranty but a month later I had to remove the door skin as there was a rattle in the door.This turned out to be one of the mechanism scurimg bolts which had not been tightend.Removal of the door skin is relatively easy, look for the caps over the securing bolts in the pull handle and beind the door release handle. There is a press home grommet where the wing mirror adjuster is housed you need to pull this out together with the ones aroud the edge of the skin before lifting the door skin. Best of luck.
  7. Remove Advertisements
+ Reply to Thread
  1. Electric window
    By ferrotty in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 09-19-2009, 10:32 AM
  2. Where can i get the electric glue for the SID repair
    By fray93 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 05-14-2009, 03:35 PM
  3. electric window
    By rapressley in forum Saab 9000 (1984 - 1998)
    Last Post: 06-10-2006, 08:59 PM
  4. Driver's Side Window - off track?
    By sadieavc in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 11-16-2005, 03:47 PM
  5. ELECTRIC WINDOW REGULATORS (REPAIR CHEAT)
    By hmcdonald in forum Classic Saab 900 (1979 - 1993)
    Last Post: 08-22-2005, 10:01 AM
