What is a Dawes Device
NEWS
+ Reply to Thread
Results 1 to 5 of 5
Thread: What is a Dawes Device
  1. #1
    Saab Junior
    Join Date
    Jul 2002
    Location
    Huddersfield
    Posts
    28
    Will it
    Make my t16 go faster
    sound differnt
    improve mpg
    impress my mates
    get more women
    or just cost me money
  2. Remove Advertisements
  3. #2
    Saabisti
    Join Date
    May 2002
    Location
    Canada
    Posts
    100
    Re: What is a Dawes Device
  4. #3
    I've been looking at one of these for the 9000 LPT. My understanding is it will allow me to up the boost from the set max/min 6psi level to a safe enough figure (say 8-10psi). In doing this I'd overide the Trionic system(in your case APC) but certain safety cut-outs will remain.
    I haven't done it because I'm a big scaredy cat and I'm not sure if I really want to lose any of the management system. This is the JW Racing website, they are the official European importers.
  5. #4
    Saab Newbie
    Join Date
    Oct 2001
    Location
    Bath
    Posts
    19
    I put one on my '92 T16S a couple of months ago.
    In effect it's a valve which you put in the line between the APC solenoid and the wastegate. Whilst the APC can start trying to open the wastegate a little at quite low boost pressures, the Dawes Device stays closed, preventing the wastegate from opening at all until a pre-determined boost level is reached.
    This level is set by you, at whatever you feel comfortable with...
    Given that the ignition will cut out when the boost reaches 1 - 1.1 bar (ish) and the APC would usually fully open the wastegate at as little as 0.75 bar, there is quite a lot of room to play with.
    Before fitting the DD my car - which has a cat - wouldn't get out of the orange sector on the boost gauge; I've set it to boost about 1/3 to 1/2 way nto the red and, bearing in mind that things may change in the winter - you can develop significantly more boost on a cold day - I have yet to get the safety cut-out to trigger.
    The limiting factor - on worn P6000's anyway - is too much torque steer, not too much boost...
    HTH
    Nick.
  6. #5
    Saab Anorak
    Join Date
    Dec 2001
    Location
    Croydon, Surrey, UK
    Posts
    763
    A device by Dawes?
  7. Remove Advertisements
+ Reply to Thread
  1. Dawes Device MBC
    By cscm094 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 06-24-2003, 12:18 AM
  2. dawes device a con ?
    By ylee coyote in forum Saab 9000 (1984 - 1998)
    Last Post: 07-26-2002, 03:33 AM
  3. dawes device a con ?
  4. Dawes Device again
    By Julian in forum Saab 9000 (1984 - 1998)
    Last Post: 04-22-2002, 09:28 AM
  5. Dawes Device again
