Chip reprogramming vs. intercooler+BIGger turbo
NEWS
+ Reply to Thread
Results 1 to 10 of 10
Thread: Chip reprogramming vs. intercooler+BIGger turbo
  1. #1
    Saab Newbie
    Join Date
    Jan 2002
    Location
    Rovaniemi, Finland
    Posts
    18
    Hi!
    I'm again in need of great wisdom. Earlier I was thinking of changing the turbo and/or adding a intercooler, but I found out that it's cheaper and easier to get the ECU -unit reprogrammed. At the moment I would be satisfied with the about 200hp, that the chip programmer claims to achieve.
    Any experiences of reprogrammed chips? Will there be some problems, or will there be a great change in the nature of the engine? Power only in the high rpms? Considerably worse mpg?
    Or just thumbs up?!
    Make
  2. Remove Advertisements
  3. #2
    Saab Anorak
    Join Date
    Oct 2001
    Location
    Westfield, East Sussex
    Posts
    661
    Re: Chip reprogramming vs. intercooler+BIGger turbo
    Without knowing the year of your 900-classic? or not?, if its a classic then the ecu only controls fueling so chipping this will not give a great increase if any, tweaking the apc box will however , a bigger turbo will not be needed to produce 200bhp, if you have a Garrett T3 then these can sustain around 20psi!! which is enough for 250+bhp, the main drawbacks of the C900 are that the intercooler has marginal airflow where its situated so ideally this should either be changed for a front mount or have a fan/water spray fitted to it to avoid heatsoak, and the ability of the gearbox to handle high power outputs or not as the case may be!.
    As for fuel consumption it will only increase if you use the performance more than you did before!!
    You will use more fuel when you first do these mods as they are addictive.Good luck
    Pete.
  4. #3
    Saab Newbie
    Join Date
    Jan 2002
    Location
    Rovaniemi, Finland
    Posts
    18
    Allright, so I once again forgot to mention my Saabs facts but here they are: 1990 Saab 900S 16v and a manual trans (thank God!), so she's a low pressure turbo sans intercooler and unfortunately there isn't a Garrett turbo but a tiny Mitsubishi one, watercooled though..
    Yeah, I quess will go on with the ECU reprogramming later this month. I hope the transmission will cope with the increased power and torque. It's a well known fact that the tranny is [expletive deleted]. And my Saab has seen some miles in her life 425000kms=264000miles and still going..
    Make
  5. #4
    Saab Anorak
    Join Date
    Oct 2001
    Location
    Posts
    661
    Personally i wouldnt bother getting anything done to the ecu at the moment, you really wont see any gains at all.
    Your car has no modifications to warrant re-programming the fueling side of things.
    Better to spend your money on getting a 900 turbo intercooler and pipework then you will be able to fit a bleed valve set to say 10psi then you would at least get near full turbo performance (175bhp).
    Pete.
  6. #5
    I'm with Tandino, I'd be surprised if anyone can 'chip' an lpt given that these cars don't have an APC to start with ...
    The proven but expensive option is to fit an Abbott Racing Chargecooler (as I've done). Makes a helluva difference. I had a FPT boots gauge fitted at the same time, and my car boosts around half-way into the red. Other 'mods', such as they are, are a JR filter and a free-flow s/s exhaust. Next to come are a RRFPR and a cat bypass.
    James
  7. #6
    This might not be useful but is Saab the only marque where people discuss performance upgrades on cars with 264,000 miles on the clock and in Northern Europe?
  8. #7
    Saab Newbie
    Join Date
    Jan 2002
    Location
    Rovaniemi, Finland
    Posts
    18
    SteveN is hilarious.. But hey, if y'all would have the same taxes in cars that we have in here, you wouldn't be laughing. At all.. EU and everyone has equal taxation and all, yeah right. Gasoline is 1,117/liter and let's say a basic 9-5 Aero sedan manual starting from 53000 €. You have to do the converting gallons/£. That's why I'm working still with my old reliable. And for James, are you sure that my Saab doesn't have an APC? She will drink happily any gasoline up from 91 octane, although we have only 95 & 98 nowdays. I would be more than happy to add bigger turbo&intercooler but I would have problems later with vehicle inspection authorities. Guys, living here in the "North" as SteveN mentioned isn't that easy. But we're trying. And we have Saabs. Atleast I'm driving a domestic car, not an import! (My Saab was built in Uusikaupunki, Finland)
    See ya
  9. #8
    Saab Anorak
    Join Date
    Oct 2001
    Location
    Posts
    661
    Your car definately doesnt have an APC system, the reason it will take any fuel from 91ron upwards is because the lpt's run a very low boost level to allow for this.
    If you cant fit a intercooler of some description and i dont see why you cant fit a genuine Saab 900 one (what official is going to know that aa lpt never came with an intercooler?) then i recommend that you leave the performance side of your car alone as the intercooler is the limiting factor in your quest for more power
    Pete.
  10. #9
    I cant say we here Stateside feel any sympathy for you. All I can get is 87, 89 and the best 91. I know the 900 and my two wheeled babys would be much happier with 95 or 98. Enjoy!
  11. #10
    Motor Mouth
    Join Date
    Jun 2000
    Location
    Preston UK
    Posts
    2,599
    Ahh there is a difference in Octane ratings used in US and in UK. MON and RON numbers - can not remember which uses what but basically the American 91 fuel isnt that much different than the UK 95 fuel - at least if I remember correctly - sure someone out there will know for sure?
  12. Remove Advertisements
+ Reply to Thread
  1. Bigger Turbo 9k Aero
    By injectie in forum Saabscene: Performance
    Last Post: 05-04-2009, 08:12 PM
  2. Turbo chip tuning company
    By wayneh in forum Saabscene: Performance
    Last Post: 07-01-2006, 05:07 PM
  3. Bigger turbo on a MY92 9000 2.3 HOT auto
    By shv in forum Saabscene: Performance
    Last Post: 11-30-2004, 03:43 AM
  4. bigger turbo
    By elliotarroyo in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 05-29-2004, 04:24 AM
  5. bigger turbo
    By saab man in forum Classic Saab 900 (1979 - 1993)
    Last Post: 03-17-2002, 05:33 PM
