Shelf life of opened brake fluid bottles
+ Reply to Thread
Results 1 to 5 of 5
Thread: Shelf life of opened brake fluid bottles
  1. #1
    Saab Afficionado
    Join Date
    Sep 2002
    Location
    Dorset, UK
    Posts
    1,749
    This was inspired by the other thread about brake discs, brake fluid life, brake pads, etc.
    I have an opened bottle of dot 5.1 which I used when I did my clutch. I now want to change a rear caliper, and I'll probably try and bleed new fluid through to all 4 calipers.
    Does an opened bottle have a shelf life similar to fluid in the car, i.e. 2 years?
    Or less? Or more?
  2. #2
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    Re: Shelf life of opened brake fluid bottles
    I would say a sealed bottle has a longer shelf life. The risk on the car is water absorbtion. Mostly through the vent holes and throught the wall of the rubber flexibles. Your bottle should be OK as long as it's not rubber. The poly or metal is impervious. So as long as you didn't get it contaminated when you first used it, I think it's OK.
  3. #3
    Turbo Talker
    Join Date
    Feb 2002
    Location
    linlithgow
    Posts
    4,215
    the hermetic seal was broken so the shelf life will depend on how well the seal on the cap seals
    If you used a significant amount then the moisture in the air that is in the void will be absorbed plus any moisture that gets past the cap...
    tricky one
    how much do you value your life ?
  4. #4
    Saab Nut
    Join Date
    Oct 2003
    Location
    West Sussex, UK
    Posts
    411
    I took a lesson from a long-time DIY mechanic. Buy the smallest new fluid containers you can, use what you have to and throw away ANY opened but unfinished container. The fluid is hygroscopic and there's no way you can stop it absorbing water.
    It's the safest thing to do.
    I change brake fluid annually, it's a habit now.
  5. #5
    Motor Mouth
    Join Date
    Jul 2000
    Location
    Polegate, East Sussex
    Posts
    2,277
    Since the bottle is fairly easy to access (well, compared to the caliper end of the brake system ) you could use a garages' fluid tester in the bottle to see how it shows up.
    A question though, what is brake fluid? Is it an oil of sorts? I'm wondering how to dispose of it, at a local amenity site.
    Nick.
  6. Remove Advertisements
+ Reply to Thread
  1. Shelf life of opened brake fluid bottles
    By johncc in forum Saab 9000 (1984 - 1998)
    Last Post: 09-30-2004, 04:49 PM
  2. brake fluid
    By ylee coyote in forum Saabscene: Performance
    Last Post: 07-01-2004, 07:10 PM
  3. brake fluid
    By french9-5 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-02-2004, 07:25 AM
  4. Brake Fluid
    By MikeH in forum Saabscene: Performance
    Last Post: 01-31-2004, 07:44 AM
