Help needed with starting problem.
NEWS
+ Reply to Thread
Results 1 to 12 of 12
Thread: Help needed with starting problem.
  1. #1
    Saab Nut
    Join Date
    May 2003
    Location
    North Carolina , USA
    Posts
    277
    Hello, I've fenished up the manual conversion on my 91 CD turbo a few days ago. Spent yesterday and today tweaking a few things to get it running right. It's been on a few trips around my neighborhood at this point, run for a total of about an hour. Was going pretty flawlessly until today. I was taking it out for a little drive again after installing a starter button. It drove for about 2-3 minutes and just cut out after coming to a stop. Now it just turns over and doesn't make any attempt to start. It was wierd because it had been driven yesterday and this morning for about 10-15 minutes each time, with absolutely no problems at all. I've checked some of the more obvious things, all fuses OK, Quarter tank of fuel. When I pulled the spark plugs I found that they were covered in carbon, so I put new ones in. No check engine light before starting. Once I try to start it, it comes on and stays on until I stop trying. Only odd thing I remember before this started is that the idle seemed to be pulsing a little. I'm really out of ideas at this point. I've got the negative lead off the battery so that it can reset the ecu, but I wouldn't think that could fix it. Also, can gas go "stale" inside of 3 months? If anyones got any suggestions I could definately use them. Thanks in advance.
  2. Remove Advertisements
  3. #2
    Wastegate
    Join Date
    Sep 2000
    Location
    Mulbarton, was Deepest Mid Norfolk
    Posts
    8,810
    Re: Help needed with starting problem.
    I would look at the last thing you changed first ( starter button). After that, all earths and wiring that will have been interfered with douring the last 3 months.
  4. #3
    Saabisti
    Join Date
    Mar 2004
    Location
    North Manchester
    Posts
    206
    Does it have an immobilizer ?
    Mine is std saab and kicks in after 3mins if engine not started and car not locked.
  5. #4
    Saab Nut
    Join Date
    May 2003
    Location
    Posts
    277
    A little update... The car is not getting spark OR fuel! I'm pretty sure something has failed, not having to do with the starter switch. The local saab mechanics have said that it is very likely the crank position sensor. Their reasoning is that the ecu wont spark without it, and that the fuel pump will not pressureize either when its in this "mode". It's almost $300, and on top of that I need a new battery. Does their reasoning sound right? I can't think of much else that could stop both the DI and the fuel pump, and it's not likely both went at the same time. (Also there both new, with less than 500 miles on either) Is there a way I can be sure it's the crank position sensor? $300 is a heck of a shot in the dark.
  6. #5
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    Well, if you are sure that there's nothing wrong with your modifications.....
    I don't have a 9000, but I had a CPS go on my 9-5 last summer. It wasn't as terminal as yours as car still ran but cut out and would re-start.
    $300 seems a lot. The one in the 9-5 is a Bosch unit. So it may be available elsewhere if the 9000 uses the same supplier. The 9-5 one cost me under £60 ($110) from Elkparts. Is the 9000 one very different?
  7. #6
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    UK price for a 9k CPS is circa £180...
  8. #7
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    £180!
  9. #8
    Saab Nut
    Join Date
    May 2003
    Location
    Posts
    277
    The mechanic was a little shocked when he looked up the price for it, seems that it's much more expensive than the surrounding years, and I suppose even on the 9-5. I'm going to pull the old one out tomarrow and see what I can see. I suppose I'll take a multimeter to it and check if it's doing anything at all. As to my starter button, I don't see how it could be doing anything like this. It started the car no-problems 2 or 3 times before I set out for the test drive. It still does a fine job of turning the engine over. I probubly started it 10 or more times with the screwdriver method before installing the switch. Also, the 9-5 has a more intelligent computer I would think. So maybe it can improvise it's timing while the 9000 just gets confused.
  10. #9
    Saab Nut
    Join Date
    May 2003
    Location
    Posts
    277
    Yet another update... Checked out the fuel pump with a drill battery, and it works fine. So what I'm wondering, what can activate a fuel pump cut off in the car? Only two I know of is over-boost and ignition problems. I'm going to take a wild guess and say it's not over-boost Correct me if I'm wrong but the ignition system consists of only the ECU, DI, and plugs. Is the crank position sensor the only one that could cause an ignition related problem? I'm praying something didn't happen to the ECU. $1000+ to get a new one.
    Edit: I did try to test the crank position sensor itself with a multimeter and breaker bar on the crank but It didn't really tell me much. According to Haynes it's resistance is double what it's supposed to be. But from the pictures their sensor looks nothing like mine.
  11. #10
    Saab Junior
    Join Date
    Feb 2004
    Location
    Hudson Mass
    Posts
    32
    try crank angle sensor, the computer wont give you fuel or spark if it doesnt know its turning.
  12. #11
    Saab Nut
    Join Date
    May 2003
    Location
    Posts
    277
    Just tested my POSITIVE battery lead (disconnected) to the top of the engine block with a multi. No resistance. So I started looking for a really bad short. The cable itself was fine, no exposed metal. Connections OK. I disconnected it from my alternator and the resistance was fine again, off the meter. The bottom bolt of the alternator is making a perfect ground to the block. My dad did knock it off the workbench when I still had the car in peices, so I'm guessing I've found my problem. I'm going to jump it with another car with the alternator disconnected tomarow and see if she runs.
  13. #12
    Saab Nut
    Join Date
    May 2003
    Location
    Posts
    277
    Problem solved! Thanks for the help guys. Alternator is still under warranty too.
  14. Remove Advertisements
+ Reply to Thread
  1. 2.2 TID Starting problem
    By Scott_9_3 in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 03-04-2010, 03:55 PM
  2. starting the audio upgrade tomorrow---ADVICE NEEDED
    By saabcrazy321 in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 04-23-2009, 02:40 PM
  3. Performance Ecu not starting car help needed
    By michaelgentry in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 01-19-2006, 03:18 PM
  4. starting problem
    By Russ in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 09-12-2004, 02:53 PM
  5. Help needed with starting problem.
    By FoeCom in forum Saab 9000 (1984 - 1998)
    Last Post: 07-26-2004, 07:45 PM
