Throttle Body
NEWS
+ Reply to Thread
Results 1 to 9 of 9
Thread: Throttle Body
  1. #1
    Regular Saab Guy
    Join Date
    Dec 2003
    Location
    Bonnie Scotland
    Posts
    92
    Throttle Body
    My car is unable to produce the power as it once did and there is an air whooshing sound when the accelerator is pressed down far enough. My mechanic tells me that it is the throttle body. It seems to have come away and he is saying that I need a replacement part - best 2nd hand he said as it will be expensive from SAAB.
    I just caught a glimpse of a hose hanging down with what seemed like a metal insert inside it. Assuming he is right, can anyone advise me of a reliable source for such a thing from a 9000 Griffen 2.3 FPT Automatic 1997?
    TIA
  2. Remove Advertisements
  3. #2
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    Re: Throttle Body
    I think you can just put the metal bit back in. It will need glueing with some high temp adhesive. I've read here that several people have done this. Try a search.
  4. #3
    Re: Throttle Body
    My CSE 2.0LPT is doing the same and I can see oil on the hose that fits to that tube under the throttle body. I haven't got round to sorting it out but I'm confident that's what's wrong. When I have time, I intend to undo the hose, remove the tube, clean it all up and glue it in with epoxy.
    www.saab9000.com - all you ever wanted to know about the Saab 9000
    www.saabits.com - stuff to help keep Saabs on the road
  5. #4
    Regular Saab Guy
    Join Date
    Dec 2003
    Location
    Bonnie Scotland
    Posts
    92
    Re: Throttle Body
    Originally posted by sgould:
    [qb]I think you can just put the metal bit back in. *It will need glueing with some high temp adhesive. *I've read here that several people have done this. *Try a search. [/qb][/b]
    They tried welding it believe it or not but it popped back out again so they suggested I need to replace
  6. #5
    Full throttle
    Join Date
    Jan 2002
    Posts
    16,524
    Re: Throttle Body
    It's probably easier with glue. I suspect the throttle body and the pipe are different metals.
  7. #6
    Saab Fan
    Join Date
    May 2004
    Location
    Silicon Valley CA USA
    Posts
    54
    Re: Throttle Body
    Do you have "JB Weld" in the UK? It's a metal glue available at the auto-parts store.
    Because they are disimiliar metals (aluminum TB and brass hose boss) welding isn't an answer.
    I believe the brass hose boss was an interference or press fit originaly.
  8. #7
    Turbo Talker
    Join Date
    Feb 2002
    Location
    linlithgow
    Posts
    4,215
    Re: Throttle Body
    jb weld is available here and very good it is and I would concurr that it would be appropriate for fixing the brass into the ally...
  9. #8
    Regular Saab Guy
    Join Date
    Dec 2003
    Location
    Bonnie Scotland
    Posts
    92
    Re: Throttle Body
    I'll let him know that jb weld is the thing
  10. #9
    Saabisti
    Join Date
    Dec 2003
    Location
    Wimborne, Dorset.
    Posts
    128
    Re: Throttle Body
    Hiya..
    The same thing happened to me a few weeks ago - it's an easy fix thankfully!
    JB Weld is the stuff - having used it myself I can safely say it's the dogs ******! You can get it from Halfords, but be sure to get the high temp one!
    You'll have to pull the Throttle body out to do it, but it's a 10 minute job to do that once you've unhooked the throttle cable and undone the inlet piping.
    Make sure that the brass insert still fits ok and give it a good clean with acetone or similar to get rid of the oil and grease that will be on it. A rub with wet and dry aill also gove it a good keying surface too. Mix up the JB Weld and gloop it over the brass tube and push it back into place. Leave overnight to cure and re-fit to get that lovely thrusting turbo boost back!
    last point - there's a small vacuum pipe just underneath the hose that fits onto that brass tube - I snagged and broke mine without realising and only got partial boost back (I think it went to the APC cos the dump valve just made a continual "pff pff pff pff pff" noise... ) Trimmed the end, re-fitted it and full boost was back!
    Sorry it's a long posting... I'm a wordy b*gger!!
    Greg
  11. Remove Advertisements
+ Reply to Thread
  1. CEL - Throttle Body?
    By pauljdh in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 06-19-2010, 06:14 PM
  2. Throttle Body
    By Jeff_bobik in forum Saab 9000 (1984 - 1998)
    Last Post: 04-15-2010, 12:51 PM
  3. Throttle body help
    By cortinadave in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 02-06-2009, 01:10 PM
  4. Oil in throttle body
    By aero-eng in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 04-19-2008, 11:29 AM
  5. It wasn't the throttle body!
    By antonyn in forum Saab 9000 (1984 - 1998)
    Last Post: 06-18-2004, 12:03 PM
