Engine question
NEWS
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Thread: Engine question
  1. #1
    Saab Afficionado
    Join Date
    Sep 2001
    Location
    Norwich, Norfolk
    Posts
    1,925
    Engine question
    Question for the experts. Can you put a 202 head on a 234 engine without any problems? Pre 93 in both cases.
  2. Remove Advertisements
  3. #2
    Wastegate
    Join Date
    Sep 2000
    Location
    Mulbarton, was Deepest Mid Norfolk
    Posts
    8,810
    Re: Engine question
    I would think so, you can do it the other way so they should be compatible.
  4. #3
    Saab Afficionado
    Join Date
    Jul 2001
    Location
    Scotty land
    Posts
    1,673
    Re: Engine question
    What about the timing chains, the 2.3 is a taller engine is it not, therefore the t/chain from the 2.0 would be to short.
    Or am I just talking pants!
  5. #4
    Saab Anorak
    Join Date
    Sep 2001
    Location
    ayr scotland
    Posts
    865
    Re: Engine question
    im with scaero on this i think you can,but we both know who to ask.
  6. #5
    Saab Afficionado
    Join Date
    Jul 2001
    Location
    Scotty land
    Posts
    1,673
    Re: Engine question
    Right!, where's the man who know's, where is he!
  7. #6
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Re: Engine question
    IIRC it affects the compression ratios- the combustion chambers are certainly a different shape, with the 2.0 being squarish and the 2.3 round. I'm pretty certain that putting a 2.0 on a 2.3 increases the compression, which is OK as long as you don't want to run higher levels of boost.
    Doing some maths on this:
    the B202 Turbos were were 9:1 compression ratio, and with a swept volume of 1985/4=496cc per cylinder, have a combustion volume of 55cc
    the B234 Turbos were were 8.5:1 compression ratio, and with a swept volume of 2290/4=572cc per cylinder, have a combustion volume of 67cc
    If we assume that most of the combustion is in the head (OK there's a small amount in the dish of the piston) that would suggest that putting a 2.0 head on a 2.3 would give a compression ration of 572/55 or about 10.4:1
    The extra displacement is achieved by a longer stroke, and "room" for that is made at the bottom of the block.
    More info on the engines can be found on Saabs.info
  8. #7
    Saab Afficionado
    Join Date
    Jul 2001
    Location
    Scotty land
    Posts
    1,673
    Re: Engine question
    Mark...What about timing chains?, or is this just rubbish cause I was sure the 2.3 was "taller".
  9. #8
    Saab Anorak
    Join Date
    Sep 2001
    Location
    ayr scotland
    Posts
    865
    Re: Engine question
    ask the man.
  10. #9
    Saab Nut
    Join Date
    Dec 2003
    Location
    Planet SAAB (SW Division)
    Posts
    335
    Re: Engine question
    (pants) *cough*
  11. #10
    Saab Afficionado
    Join Date
    Jul 2001
    Location
    Scotty land
    Posts
    1,673
    Re: Engine question
    I did, but it's very technical now!
  12. #11
    Wastegate
    Join Date
    Sep 2000
    Location
    Posts
    8,810
    Re: Engine question
    Originally posted by Axl:
    [qb]Mark...What about timing chains?, or is this just rubbish cause I was sure the 2.3 was "taller". [/qb][/b]
    Tis Rubbish I'm afraid, the 2.0, 2.1 and 2.3 heads up to MY93 are bolt and patten compatible between cars.
  13. #12
    Wastegate
    Join Date
    Sep 2000
    Location
    Posts
    8,810
    Re: Engine question
    Also the 2.3T head have larger (exhasut?) valves, but not by much I think, and not as larger as the Abbott big valve conversions.
  14. #13
    Saab Afficionado
    Join Date
    Jul 2001
    Location
    Scotty land
    Posts
    1,673
    Re: Engine question
    Oh well, thats me told!!, I was sure they were taller, obviously not, well at least I know now, cheers
  15. #14
    Wastegate
    Join Date
    Sep 2000
    Location
    Posts
    8,810
    Re: Engine question
    The 2.3 engine block casting is not compatible with the old 2.0 casting used in the C900's as it is too tall and not cast for a 45 degree slant.
    The later GM 900 2.0 engine casting is also too tall as it was recast for near upright use.
    This is probably where your confusion comes from.
    The older engines were 90mm diameter and 78mm throw for 2.0 and 90/90 for 2.3 with a 6mm longer throw crank (which is to big to fit the C900 sump without fouling).
  16. #15
    Wastegate
    Join Date
    Sep 2000
    Location
    Posts
    8,810
    Re: Engine question
    Google's great
    Head Displacement:
    When swapping heads around, it's important to note that the shape & dimensions of the combustion chamber is't the same. *The following info comes from Nick Jacob:
    B201 48CC
    B202 *(MY1985 only) - 42CC
    B202 46CC
    B212/B234 (essentially the same head) - 48CC
    With that information, you'll see that putting a B212 or B234 head on your B202 motor will drop the compression ratio, and putting a 1985 B202 head on any later car will substantially increase it.[/b]
    Although a 1996 on B202 head will not greatly impact CR.
  17. Remove Advertisements
+ Reply to Thread
  1. Engine Temp question
    By mattau in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 12-24-2010, 08:08 AM
  2. engine/gearbox question
    By lizard9000 in forum Saab 9000 (1984 - 1998)
    Last Post: 05-16-2006, 12:47 PM
  3. Engine question
    By 9000CS23T in forum Saab 9000 (1984 - 1998)
    Last Post: 07-10-2005, 05:15 PM
  4. engine bay question
    By slidejules in forum Saab 9000 (1984 - 1998)
    Last Post: 06-14-2003, 07:47 AM
  5. engine bay question
