Rear shock removal problem
NEWS
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Thread: Rear shock removal problem
  1. #1
    Saab Nut
    Join Date
    Mar 2003
    Location
    Lymington, Hampshire, UK.
    Posts
    252
    Hi I'm in the process if removing the rear axle tube.
    All went well until I tried to withdraw the bolt that runs through the shock bottom and anti-roll bar mount (nuts came off ok).
    One side is well and truely stuck fast, the other just springs in the rubber bush when I try and pursuade it out.
    I'm sure this must be a common headache - any tips guys? .....Please!!
  2. Remove Advertisements
  3. #2
    Saab Nut
    Join Date
    Jul 2003
    Location
    Dublin, Ireland formally Luton
    Posts
    341
    Re: Rear shock removal problem
    I know how you feel Jules, I have two dodgy shocks on the back of my car, due to the fact that the bolts wont come out...
    I thought I was smart taking the easy option bringing the car into kwik fit to get new shocks... didnt work out as they couldnt get the bolts out... had a go myself sprayed the living daylights out of them with wd40... didnt seem to work despite taking off one of the rear discs and clobbering them out. That didnt work either, so the disc went back on and the shocks are still in place.
    Ive managed to get hold of a spare set of bolts so I now have the option of cutting them off... it may come down to that. I may give it a go to try and put some moderate heat onto the area to see if it helps unstick all.
    If anyone comes up with any better ideas, Im all ears!. Your not alone Jules!
  4. #3
    Saab Nut
    Join Date
    Dec 2003
    Location
    Planet SAAB (SW Division)
    Posts
    335
    the chimps at kwik-fit zoo couldnt get them out? why doesn't that suprise me not a very constructive answer i know, but ut is late..
  5. #4
    Saab Anorak
    Join Date
    Feb 2003
    Location
    Fife,Scotland
    Posts
    765
    jules, have you tried plus-gas ? it is ten times better than wd40, it is designed for siezed and rusted parts, bit like Carlsberg !! "reaches parts others can't"
    HTH Haggag01
  6. #5
    Saab Newbie
    Join Date
    Apr 2004
    Location
    Mansfield, Notts
    Posts
    16
    I've not seen these, but can you get a puller onto it?
    It's got to be better than doing Mercedes self-levelling shocks anyway; they're spheres fed with hydraulic fluid, almost inaccessible, and the unions inevitably seize so you end up cutting and renewing the pipes. Oh, and they're £135 each
  7. #6
    Regular Saab Guy
    Join Date
    Apr 2003
    Location
    Gaithersburg, MD
    Posts
    79
    We have a product on this side of the pond called PB Blaster. Its not a penetrating oil like WD40 but a penetrating catalyst. It eats the rust and frees stuck bolts. I've used it successfully to break free many rusty components on a VW Golf project of mine. The car had been sitting outside for probably 5 years and then the 10 years before that was very poorly maintained. Even the toughest of stuck buts and bolts spun freely with ease after a few days of spraying them.
  8. #7
    Saab Nut
    Join Date
    May 2003
    Location
    North Carolina , USA
    Posts
    277
    You're at the fun part! I found that attaching a C-clamp to the thread end of the bolt, and the other side, not on the bolt head, but as close as you can get to it. Then apply some liquid wrench, and turn it a few times. Keep tension on the C-clamp and keep turning the nut with a wrench, it will eventually come out enough for you to pull on it while turning. Not sure how clear all that is, but it works well! Hope that helps.
    Reread post: The other bolt WILL turn with enough convincing. There not threaded to anything except the nuts on the end which you have removed. I had a similar problem with one of mine. Breaker bar and a few curse words did it.
  9. #8
    Turbo Talker
    Join Date
    Feb 2002
    Location
    linlithgow
    Posts
    4,215
    they all do that sir....
    This is the royal pita job..
    After 4 hours of struggling I gave it to my very local man who got out the oxy acetylene
    I tried everything .....
    good luck !!
  10. #9
    Saab Nut
    Join Date
    Mar 2003
    Location
    Posts
    252
    Hmmm..... What can I say?!
    I guess a combination of WD40 type stuff and some heat and puller is in order....
    Cheers all.
  11. #10
    Saab Anorak SJ's Avatar
    Join Date
    Jul 2003
    Location
    East Yorkshire
    Posts
    836
    I had one totally seized, wouldn't turn at all. Eventually I cut through the bushing tube and the bolt with a padsaw (hacksaw blade) on both sides of the shock. This left it with nothing to hold on to...
    ha, ha, beaten the B*****D
  12. #11
    Saab Afficionado
    Join Date
    Jul 2003
    Location
    London
    Posts
    1,597
    mine came out no issues. Don't know what the fuss is about.
  13. #12
    I spent four hours this weekend with Big Nev trying to get the bolts out only to be defeated. I now have spare bolts and two new anti-roll bar bushes ready so that I can cut through the bolts this weekend.
    Alanb
  14. #13
    Saab Nut
    Join Date
    Mar 2003
    Location
    Posts
    252
    SO it ain't looking good then!
    I think I'll get hold of some new bushes and bolts - I can't be arsed to spend several more hours... only to be defeated!
    It's weird though - even the one which isn't siezed seemes to be stick in the rubber bush and won't budge.
    Ahhhgggh! The only reason I need to remove the bolts is to replace my rear axle tube (someone has either lost the back ens and hit a kerb, or jacked it up on the tube - either way the back wheels are on the p*ss!) ... the shocks are fine!!
  15. #14
    Motor Mouth
    Join Date
    Jun 2000
    Location
    Preston UK
    Posts
    2,599
    Never tried it myself so its only an idea - but as you need to drop the rear axle tube why not drop it with shocks and trailing arms still attached (assuming front trailing arms are not stuck solid!). Then you will be able to get to the shock/tube/arm bolts much more easily - either to cut them or get some heat on or c-c-plamps etc.
  16. #15
    Saab Nut
    Join Date
    Mar 2003
    Location
    Posts
    252
    Cheers Adrian - fantastic idea, I'll give it a bash.
    Failing this, does anybody know the correct part name for this bush? (so I can order another if I break it)
    Am I right in thinking that it's NOT the ARB bush? (as that is located further towards the middle of the ARB)
    Many thanks.
  17. Remove Advertisements
+ Reply to Thread
  1. Rear suspension shock absorbers - DIY or not?
    By andharv007 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 11-05-2011, 05:23 AM
  2. Rear shock tower rust
    By c130mike in forum Saab 9000 (1984 - 1998)
    Last Post: 04-06-2008, 03:39 AM
  3. Cracked rear shock top mount!!!
    By merekat in forum Saab 9000 (1984 - 1998)
    Last Post: 07-13-2005, 05:44 PM
  4. Rear shock removal problem
    By badman in forum Saab 9000 (1984 - 1998)
    Last Post: 04-27-2004, 05:53 AM
  5. 96 Rear shock mounting.
    By artdjones in forum Saab 95 & 96 Two stroke and V4 (1949 - 1980)
    Last Post: 02-11-2004, 12:41 PM
