New timing chain!
Guys,
I need to replace my '93 Aero timing chain. Is it a cylinder head off job? What is the likely cost?
Simon
Re: New timing chain!
If you just want to replace the timing chain, a new chain can be "wound on" with everything in place. However, what are the symptoms? How do you know it's the timing chain not the balance chain? How many miles has it done? How long are you going to keep it?
When mine went funny, it turned out to be a sprocket on the balance shaft chain that had worn allowing the chain to jump and the balancer shaft to become an inbalancer shaft.
Give us more info please.
Thanks Mark,
The car has done 148k. Last time it was in WMSS, I was advised the chain was slightly noisy on start up- since then the sound is more slightly more pronounced and I am worried about it failing! It sounds like a loose rattle from the chain end of the engine, it lasts for around 15 seconds then slowly dissapears.
I intend to keep the car for at least another couple of years- its been very well looked after and is in A1 condition (now the gearbox has been rebuilt and the engine mounts changed!)
Simon
I've booked it into WMSS, £150 all in!
I've decided to get the front wishbone bushes changed for poly ones too!
Simon
Sounds like you've got things under control. Hopefully the experts are right and it is just the chain. Good luck.
WMSS, who/where's that?
Mine needs doing but I'm cautious that it's all very well just changing the chain but what's the condition of the sprockets and guides?
A new chain on old worn sprockets is usually a bad idea.
David.
wise to do the whole lot!!. it can be done with head in place nice job it is not as bad as it seems. at least u have peace of mind noing its all new. no bits to snap off or go crunch
By timmay in forum Saab 9000 (1984 - 1998)
Last Post: 10-15-2005, 06:15 PM
By kimbo.b in forum Classic Saab 9-5 (1997 - 2009)
Last Post: 07-18-2004, 01:06 PM
By tahir in forum Classic Saab 9-5 (1997 - 2009)
Last Post: 03-03-2004, 04:11 PM
By Wafoo in forum Saab 9000 (1984 - 1998)
Last Post: 12-27-2002, 02:44 AM
By idzyn in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
Last Post: 01-19-2002, 04:09 PM
- You may not post replies
- You may not edit your posts
Forum Rules
