Climate control panel removal
Hi All.
Before i get fiddling about.. Can anyone tell me how to remove the climate control panel from my 1994 Aero?
I need to replace a bulb.
Many thanks!
Re: Climate control panel removal
Pull your radio out.. then reach into the hole.. and push from behind.. out it pops.. then unplug the multi-plug.. sorted..
Then all you need to do is unscrew the casing.. and replace the lamps..
Very easy job.
If you find that the bulbs are OK (there are 3) you may have the "missing pixel" problem.
Written instructions on how to get inside the ACC unit and try a fix are here . Sorry, there are no pictures (yet).
The first bit of the instructions will get you to the bulbs anyway.
Maybe, its just my car but below the acc panel is the ciggy lighter and ashtray and then the stereo ? probable makes it even easier to get to the panel the ashtray comes out with a clip.
Haggag01
Sorry to be a little 'picky' here, but there are 4 bulbs and holders inside the ACC control unit. I should know, because I've got one open in my hand now!
Small and insignificant point I know. I'll slap my own wrists and get my anorak on!!!
Sgould's post refers to the 9-5 ACC. The 9000 ACC is quite different. In the ACC2 units in my '95 and '96s, there are three bulbs, accessed by removing the six cross-head screws securing the front panel and unclipping the panel. Older units may have a different number of bulbs.
The bulb holders can be removed by turning anticlockwise. You can simply throw away the entire bulb/holder assemblies and replace with new units, available at your Saab dealer for loadsamoney, or remove the wire-ended bulbs from the holders and replace with part number WQ13 from Maplin at 79p each (or £6.70 for 10).
You're right. The 9000 SID is completely different
That's what comes of looking at posts via the "Active Topic" link instead of the forum index
The 1993 and prior ACC's have a 4 bulbs and a metal top/rear which can be removed, but is basically the same.
The 1993 and prior's have 1 bulb fro each button column.
By Dan Cuthbertson in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
Last Post: 02-17-2011, 03:46 AM
By sebco in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
Last Post: 07-31-2008, 03:42 AM
By mac_xpert in forum Saab 9000 (1984 - 1998)
Last Post: 02-29-2004, 05:45 PM
By maxter in forum Classic Saab 9-5 (1997 - 2009)
Last Post: 01-10-2002, 10:43 AM
By Dan Cuthbertson in forum Help, Advice, Saabs and Motoring
Last Post: 12-31-1969, 07:00 PM
- You may not post replies
- You may not edit your posts
Forum Rules
