ABS Valve?
Hello all,
I am not a mechanic but, I think I can still spot a snow job when I see one. Let me explain. My recently purchased 91 Saab 9000 Turbo lost all pressure in the clutch pedal. I had it towed to my mechanic and six days later he called to tell me I needed a new ABS Valve. The good news being (he said; seeing that Saabs are an uncommon car in the united states) he found three in the state of Pennsylvania,USA. The bad news being that a new one would cost me $3500.00 and a rebuilt one would cost me $1800.00 with a $1000.00 core charge. He then told me that I should dump the car and then offered me a $1000.00 for it . Now I don't know what to do. I asked him if he could rebuild it himself and he told me he didn't know how. I need some advice.
Re: ABS Valve?
hii think the mechanic may moonlight as a conman
if you lost all pressure in your pedal there are only 4 things that would cause it
1, master cylinder faulty approx £45+vat
2, cluch pipe faulty £ 56+vat
3 clutch slave cylinder faulty £45 = vat
4 clutch pressure plate springs worn approx £85 + vat
these are english prices obviously to translate add 17.5% and then multiply by 1.8
would do it but knackered and just got in from work
HTH
mark
Re: ABS Valve?
oh sorry for being rude aswell
welcome to saabscene
Re: ABS Valve?
Welcome to Saabscene.
Has your mechanic explained how the ABS system is connected to the clutch yet??
The clutch gains it's fluid from the same resisvour, but that is it, and the volume of fluid used by the clutch is tiny.
Me thinks that there is somethingfunny going on here.
Re: ABS Valve?
Thanks marks carlssons,
I figured him to be a con but, what is an ABS valve? He said that it won't even hold hydrolic fluid.
Re: ABS Valve?
what scaero is saying is what he is on about, the resevoir that holds the brake and clutch fluid,
this is seperate from the servo,
if i was you i would get the car back and take it else where
mark
By Peterbfd in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
Last Post: 06-01-2009, 07:39 AM
By wise1 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
Last Post: 08-26-2008, 07:12 AM
By bravocars1 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
Last Post: 01-30-2008, 05:25 PM
By asix in forum Help, Advice, Saabs and Motoring
Last Post: 12-10-2002, 04:21 PM
By wise1 in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
Last Post: 12-31-1969, 07:00 PM
- You may not post replies
- You may not edit your posts
Forum Rules
