Will Carly bits upgrade my eco?
NEWS
+ Reply to Thread
Results 1 to 9 of 9
Thread: Will Carly bits upgrade my eco?
  1. #1
    Saabisti
    Join Date
    Feb 2004
    Location
    Ayr Scotland
    Posts
    145
    Heres one for us to chew over-:
    I've found a G reg carlsson in a local breakers and the thought came over me; can I use parts off the carly to upgrade my 2.0 eco (93)?
    or to put it another way what gives the carly 200 bhp?
    Is it a different turbo or ecu that gives the extra power?
    Whats the thinking out there? is this a cheap upgrade option?
  2. Remove Advertisements
  3. #2
    Re: Will Carly bits upgrade my eco?
    Is that a CD or hatchback? If it is a CD, I'll have the bumper and withdraw the rest of the kit from sale.
    But in answer to your question;
    1. You can't use the ECU as the Carlsson was used Jetronic fuel control and a separate APC (turbo) control box, wherease you can is Trionic.
    2. You could "possibly" use the springs. Perhaps someone else could verify this?
    3. You could use the Intercooler and APC Solenoid valve, if your eco doesn't have an IC or Solenoid valve to convert your car to an FPT by obtaining the correct ECU for your car.
    3. If the wheels are 16" 3-spoke Aeros .. BUY THEM ANYWAY, they are very well sought after.
    HTH
    Jason.
  4. #3
    Saabisti
    Join Date
    Feb 2004
    Location
    Ayr Scotland
    Posts
    145
    Hi jason,
    The carly is a cd, if memory is right i think the back bumpers goosed, think the front is intact though, I can check next week if you like.
    The wheels are long gone unfortunately, i'd have loved them for mine.
    So you think the springs might fit? i hadn't thought of them... if anyone can confirm i'd appreciate.
    You also think the i/c might fit? scuse the ignorance but what will that do for my car?
    really gratefull for the help,
    davy
  5. #4
    Originally posted by Big Davy:
    [qb]Hi jason,
    really gratefull for the help, * * * *
    davy [/qb][/b]
    IIRC the early ecopower (LPT) cars didn't have intercoolers fitted, you can verify that if you want. Fitting an i/c will ensure that you can run higher boost levels safely and is standard fit on all full pressure turbos. One more thing is your car a 2.0 or 2.3, as I just remembered that there was no FPT 2.0 after 1990, so if your car's a 2.0 the only route you can go to up the power is to get your existing ECU reprogrammed or swapped for a repgrammed one, Maptun, Abbott and Speedparts all do upgrade kits for 2.0 LPT's.
    You have a new private message by the way.
    Jase.
  6. #5
    Wastegate
    Join Date
    Sep 2000
    Location
    Mulbarton, was Deepest Mid Norfolk
    Posts
    8,810
    Being a 93 2.0 eco, it may not be trionic, as I think that was 1993 only and 2.3 FPT only , being rolled to other models in 1994.
    If you have DI on your car, then the DI/APC may work (or it may not...) some seem to be my finiky.
  7. #6
    If it is a 93 lpt non balancer shaft motor, then it is not trionic.(B202=LH Jetronic/ B204=Trionic)
    M.
  8. #7
    Saabisti
    Join Date
    Feb 2004
    Location
    Ayr Scotland
    Posts
    145
    Hi guys, gratefull for all the advice. My car is a September 1993 so i am presuming it has the newer balancer shaft engine.Will engine number confirm this?
    presuming it is, the general answer to my original question will be no the carly bits won't fit, just my luck!
    Does anyone out there know if the springs off the carly will fit? If they do is it a worthwhile swap?
    thanks to all
    Davy.
  9. #8
    Saabisti
    Join Date
    Feb 2004
    Location
    Ayr Scotland
    Posts
    145
    Quick update, I checked my engine no.starts B204 so looks like the balancer shaft engine with trionic.No cheapy upgrades then!
    Thanks again to all who helped
    Davy
  10. #9
    So as a 94 model. You need an intercooler & pipes at around £80 to £100. Then £500 to Speedparts or Maptun or similar.
    That should take you from 150 to 200 bhp!
    Have fun!
    M.
  11. Remove Advertisements
+ Reply to Thread
  1. FOR SALE - 308mm 9-5 Brake upgrade bits. . . .
    By sgould in forum Saab Parts / Accessories, FOR SALE and WANTED
    Last Post: 05-31-2008, 01:31 PM
  2. CS Carly anyone?
    By StealthDJ in forum Saab 9000 (1984 - 1998)
    Last Post: 05-12-2005, 11:14 AM
  3. Will Carly bits upgrade my eco?
    By bigdavy in forum Saab 9000 (1984 - 1998)
    Last Post: 02-23-2004, 10:35 AM
  4. carly
    By bagpussxyz in forum Saab 9000 (1984 - 1998)
    Last Post: 07-22-2003, 09:56 AM
  5. carly
