Speedometer Drive Failure
NEWS
+ Reply to Thread
Results 1 to 12 of 12
Thread: Speedometer Drive Failure
  1. #1
    Saab Newbie
    Join Date
    Sep 2003
    Location
    Essex
    Posts
    10
    Could someone give me an idea of the amount of work required to replace the nylon speedo drive wheel that is mounted on the differential (used to drive the speed sensor)
    Are there any short cuts without removing the transmission and is it a job for an advanced DIY mechanic job.
    (Saab 9000 CSE 2.0i LPT 1994)
  2. Remove Advertisements
  3. #2
    Turbo Talker
    Join Date
    Feb 2002
    Location
    linlithgow
    Posts
    4,215
    Re: Speedometer Drive Failure
    sharp intake of breath...
    not an easy job at all ...
    It means taking the gearbox out and there is a dissasembly of the gearbox parts to get to the offending item
    I have not done it but the local dealer saw me coming and charged £1200 for the job
    A good independant will be considerably less
    abbott charge £600 for a tear down and re-build
    if nothing else is wrong that will be £600.50 to you !!
    It is possible to do DIY but it will be a haynes 4 spanner job..
    There has been some-one who has done it and has posted the procedure on here so its worth a search..
    BTW welcome to the board !!
  4. #3
    Saab Newbie
    Join Date
    Sep 2003
    Location
    Essex
    Posts
    10
    Thanks for the info.
    Is it worth replacing any parts whilst am at it? (ie. is it worth replacing transmission parts - it's done 128k miles)
    PS. Is there any more detailed info available than Haynes?
  5. #4
    Wastegate
    Join Date
    Sep 2000
    Location
    Mulbarton, was Deepest Mid Norfolk
    Posts
    8,810
    The jobs a beast.
    I've gone down as far as the diff, but not any further and it took 2 whole days from driveable to driveable. (1 day to remove and refit, one to strip and rebuild.
    Add another 1-2 hrs to remove and refit the diff.
    Other things that will need replacing very soon.
    All 4 bearings for the input and output shaft (about £20 each)
    Maybe 1 or 2 of the hubs at £80 each as the inernal splines wear badly (cheaper and softer than wearing the very expensive shaft...)
    The crushable bushing (a must replace)
    Possibly a circlip or two
    Maybe the 5th gear cog, it's very small, takes lots of hard and wears it internal splines (seen as slop/slack
    The top lock nut that holds the lot together
    Think about chnaging all 4 synchro's, or at least check for wear.
    Think about changing the gear box linkage bush (£20) and gearbox mount bush (£35) while the lots out.
    That's probably it for starters..
  6. #5
    Saab Newbie
    Join Date
    Sep 2003
    Location
    Essex
    Posts
    10
    Thanks Andrew
    I have heard it may be possible to get at the offending item by going in from the side of the diff ? is this really possible?
    Can i get a non-nylon part as a replacement (i would rather it wear out the teeth on the sensor as it's much easier to replace.
  7. #6
    Wastegate
    Join Date
    Sep 2000
    Location
    Posts
    8,810
    I wouldn't have thought you could do it through the inner driver exits as the diff is mounted firmly (very) by big bearing feom inside the gearbox casting.
    The nylon wheel would be on the larger shiney ring at the bottom of the diff in the picture here:-
    The inner driver for the dricers side is much smaller than the passenger side as it does not encompass the CV part as it just fits to the tranfer shaft.
    Even these bits can get hare to get out...
  8. #7
    Saabisti
    Join Date
    Jan 2003
    Location
    Wokingham
    Posts
    240
    heres a thought,
    what about an aftermarket device to generate the signal for the speedo??? i know these are available for aftermarket speedos, so i guess it is possible that they might drive the saab item.
  9. #8
    Saabisti
    Join Date
    Oct 2003
    Location
    Northern Ireland
    Posts
    198
    Absolutely. That's just too much time and expense just get a working speedo on a vehicle with 126,000 miles. My 91 9000i also has an erratic (and sometimes non-working) speedo. It happened after a gearbox change. But I can tell you - the box isn't coming out again! How can you easily tell exactly what's wrong - i.e. is it the gear or the sender?
  10. #9
    Wastegate
    Join Date
    Sep 2000
    Location
    Posts
    8,810
    The gear on the sender can be checked (see pic above), the sender and spedo head can be checked.
    Also, an finger in the sender hole will inform the digit owner as to the state of the nylon drive cog
    I did look into the possibility of building a replacement sender or using the ABS senders, but it all got too difficult (do a search of the 9000 archives and see....)
    pulse rates per mile/km and repulse rates are mad.
    ABS used 43? teeth per wheel rpm
    Gearbox uses another for speedo and trionic speed feed (25 ish per turn)
    SCC uses a repulsed signal from speedo head at about 43000 per mile (or Km)
    What I do know is the Trionic T5 eventually goes a bit mad when it hasn't had a speedo feed for a while....
  11. #10
    Saab Newbie
    Join Date
    Sep 2003
    Location
    Essex
    Posts
    10
    I would be interested to know if anyone knows of an after market product that could reduce the cost (ie. no tranmission removal).I guess that is at least one of the reasons why it now comes from a sensor on the rear hub on 9-5s? (as i understand it).
  12. #11
    Saabisti
    Join Date
    Jun 2003
    Location
    Music City
    Posts
    243
    When mine went it turned out that the sensor had locked up and stripped the inside of the nylon gear that connects to the sensor (Scaero's pic). If the problem is with the sensor or any of the parts pictured you shouldn't need to remove the tranny; at least I didn't. Just a thought.
  13. #12
    Saab Newbie
    Join Date
    Sep 2003
    Location
    Essex
    Posts
    10
    Following up from the failed speedo drive gear in the gearbox, I eventually got the job done by an independant.
    The job cost a staggering £800 which included the cost of the replacement gear (£5) to get the speedo working again.
    Moral of the story is that if you have a saab 9000 that is getting old and the speedo drive gear fails, think very very carefully before embarking on getting this job done. It may prove uneconomic.
  14. Remove Advertisements
+ Reply to Thread
  1. Speedometer Error
    By jjirvine in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 02-20-2010, 10:24 AM
  2. speedometer
    By michael wilson in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 07-13-2009, 09:22 AM
  3. Speedometer Light Failure?
    By garfieldebbs in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 03-15-2009, 02:12 PM
  4. speedometer signal for gps
    By sergvillarreal in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 05-25-2007, 03:12 AM
  5. Speedometer Drive Failure
    By gratroweb in forum Saab 9000 (1984 - 1998)
    Last Post: 01-31-2006, 06:34 AM
