Turbo Question
NEWS
+ Reply to Thread
Results 1 to 7 of 7
Thread: Turbo Question
  1. #1
    Saab Afficionado
    Join Date
    Sep 2001
    Location
    Norwich, Norfolk
    Posts
    1,925
    Turbo Question
    What would be the effect of fitting a TD04 turbo onto a 2.3FPT, as a replacement for the T25, without changing any software in the ECU? Would it have any adverse effects on the autobox?
    I just want to know if anyone has done it before and what the outcome was.
  2. Remove Advertisements
  3. #2
    Banned
    Join Date
    Dec 2002
    Location
    UK
    Posts
    2,917
    Re: Turbo Question
    Neil, I'm sure you'll get a more relevant answer soon but when I looked at doing this to my 9-5, ie fitting the Aero TD04 turbo to a LPT the guys suggested I'd get more turbo lag due to the bigger turbo and would need to get the ECU upgraded to use it to any benefit too
    Not sure if the same applies to your application as yours is already a FPT
  4. #3
    Re: Turbo Question
    Friend of mine has a TD04 on his CDE 2.3FPT, but with uprated software too - not sure what the effect would be with just the standard ECU.
    James
  5. #4
    Saabisti
    Join Date
    Jan 2003
    Location
    Wokingham
    Posts
    240
    Re: Turbo Question
    i think these turbos are fairly similar in abilities, so try it and see...... i'm sure the car will still go OK.
  6. #5
    Re: Turbo Question
    Originally posted by Neil(CS2.3T):
    [qb]What would be the effect of fitting a TD04 turbo onto a 2.3FPT, as a replacement for the T25, without changing any software in the ECU? Would it have any adverse effects on the autobox?
    I just want to know if anyone has done it before and what the outcome was. [/qb][/b]
    On a pre-Trionic car? I might be able to tell you fairly soon, although I've been assured that the APC will adapt.
    But from what I've been told, there probably wouldn't be any major power gains from doing this, the APC would need to be reprogrammed to provide a boost curve to exploit the new turbo. That is the bigger problem, unless you're happy using an MBC of course.
  7. #6
    Saab Afficionado
    Join Date
    Sep 2001
    Location
    Norwich, Norfolk
    Posts
    1,925
    Re: Turbo Question
    I'm not particularly after a power gain at the moment. My T25 is on it's last legs (cracked housing and now smokes on run down after high boost). I have a TD04 sitting in the garage so was thinking of putting it to use rather than sourcing another T25. The thoughts above are basically what I was thinking so I'll probably give it a go shortly. (Might also get rid of the horrible wastegate rattle I've got.)
    Thanks guys.
  8. #7
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Re: Turbo Question
    The only difference will probably be a bit more lag as the TD04 is bigger. Other than that, go for it.
  9. Remove Advertisements
+ Reply to Thread
  1. Turbo Question
    By ecaroppo in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 03-10-2011, 01:25 PM
  2. Turbo Question
    By dan_walker in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 09-05-2007, 12:18 PM
  3. turbo question - 96' 9000 cs turbo
    By morgs in forum Saab 9000 (1984 - 1998)
    Last Post: 12-01-2006, 01:57 PM
  4. t25/28 turbo question
    By 9-5 aero in forum Saabscene: Performance
    Last Post: 02-15-2006, 03:29 AM
  5. Turbo question
    By serjeant in forum Saab 99, 90 (1969 - 1984)
    Last Post: 10-06-2003, 01:26 PM
