Oil Change
Hi All,
Got my local guarage to do a oil change whilst i waited on Sun Morn.. I supplied the Mobile 1 and Saab filter.
My question is I gave him 5 liters of Mobil 1. When I checked the oil level this morning the oil was on the A of MAX, therefore too much (the dipstick looks like this MIN| |MAX) Now he didnt give me back any oil. What is the oil capacity of a 2.3 FPT and do I need to drain some off tonight or will I be OK with that level?
Thanks Ant
p.s. the car does not burn any oil at all..
Full throttle
Re: Oil Change
I think it's about 4.5 litres... but you can check by looking in the owners manual
Re: Oil Change
Originally posted by Mark E:
[qb]I think it's about 4.5 litres... but you can check by looking in the owners manual * * *[/qb][/b]
Thanks. So do I need to drain the excess??
Re: Oil Change
Haynes manual states
B202 - 4.2 litre
B234 (upto 93) - 4.3 litre
B204 & B234 (94 onward) - 5.5 litre
with 1 litre between min & max on dipstick.
Hope this helps,
Pete
Re: Oil Change
Yeah I thought 5.5 for me too, but this is from BillJ's site I have just found:
B202: 4.0 litres
B204: 4.7 litres
B234: (to 1993) 4.3 litres
B234 (1994 on) 4.7 litres
B308: 4.5 litres
Difference between MAX and MIN dipstick marks: 1.0 litre approx.
Well all I know is I am over the MAX line. Just dont know whether I need to drain the excess or not.
Re: Oil Change
How much over is it? Can you extrapolate from the 1 litre min-max distance to guess how much over you are? suppose it would be advisable to drain excess off, never found out why, if at atmospheric pressure, i.e. at dipstick and various breathers, then overpressure should not occur. But maybe something else goes wrong when too much oil, anybody want to instill a little knowledge?
Cheers,
Pete
Re: Oil Change
overfilling can cause the crank to hit the oil pool,resulting in oil going to places it should not and at worst,the crank failing.
Re: Oil Change
Originally posted by MikeH:
[qb]overfilling can cause the crank to hit the oil pool,resulting in oil going to places it should not and at worst,the crank failing. [/qb][/b]
Drainage can out tonight then..
Re: Oil Change
It has just been pointed out to me that the crank hitting the surface of the oil pool will result in the oil becoming aerated and the pump delivering a air/ oil mixture to the detriment of the bearings.
Re: Oil Change
Have a look at The Oil Bible(Chris Longhurst) about half way down -
http://www.chris-longhurst.com/carbibles/index.html
Mike
Re: Oil Change
Drained some out tonight, was only over by about .2 of a litre. Sorted
Re: Oil Change
I remember years ago BMC had problems with blown up engines in Austin Maxis and Pricesses - but only in Australia.
It seems that on a "better safe than sorry" basis, Australians regularly topped up the oil to well over the "full" mark, resulting in nicely aerated oil.
By sidlaw72 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
Last Post: 09-14-2008, 04:58 PM
By BRADSMCFC in forum Classic Saab 9-5 (1997 - 2009)
Last Post: 06-09-2005, 06:04 PM
By bonny in forum Saab 9000 (1984 - 1998)
Last Post: 04-13-2004, 08:02 AM
By John Milton in forum Help, Advice, Saabs and Motoring
Last Post: 01-24-2003, 04:13 PM
- You may not post replies
- You may not edit your posts
Forum Rules
