Too Sloooow!!!
NEWS
+ Reply to Thread
Results 1 to 5 of 5
Thread: Too Sloooow!!!
  1. #1
    Saabisti robjgc1969's Avatar
    Join Date
    Mar 2003
    Location
    Eastbourne
    Posts
    171
    Too Sloooow!!!
    I after some help with finding out the fault with my slow 2.3 FPT 95 Auto. I've had a 91 year before and I'm as far as I know there were no mods done and it easly did 0-60 in sub 6.5 and could show 138 on the clock. I've also had a 2.0 FPT Auto, slower of course. My current one does 0-60 in 7.6 but more importantly is a slug when overtaking - feels slower than my 2.0. The APC gauges on all 3 cars show the same on full throttle. I borrowed cdcarlsons manual bleed valve and on almost max adjustment it just about goes into the second red which is less than with the APC connected. If I turn the manual bleed valve up just one notch more - which is max the fuel cut comes in - feels just like you've blown the gearbox!! I should know done 2 autos boxes before!! -Doh!! scrap the car. Obviously I've got a fault elsewhere as you should not have to turn the bleed value up to max. Cheers for any help.
  2. Remove Advertisements
  3. #2
    Motor Mouth
    Join Date
    Jul 2000
    Location
    Polegate, East Sussex
    Posts
    2,277
    Re: Too Sloooow!!!
    Try readapting the apc by pulling and replacing fuse no.5 Rob!
    Nick.
  4. #3
    Re: Too Sloooow!!!
    Bear in mind also that the '95 is much higher-geared than the '91.
    www.saab9000.com - all you ever wanted to know about the Saab 9000
    www.saabits.com - stuff to help keep Saabs on the road
  5. #4
    Saab Afficionado
    Join Date
    Jun 2000
    Location
    Forfar,Angus Scotland
    Posts
    1,242
    Re: Too Sloooow!!!
    Bear in mind also that the '95 is much higher-geared than the '91.[/b]
    I have a '96 2.3FTP and it feels tame compared with the previous 2.0FTP's which I've owned. Apart from the higher gearing I also feel that the engine characteristics have been changed from the previous years - less peaky and wider spread of power.
  6. #5
    Join Date
    Mar 2003
    Location
    Eastbourne
    Posts
    171
    Re: Too Sloooow!!!
    I,ve taken her out on an adaption run and its helped. With the help of some borrowed specalist tools it is now running an extra 6bhp and taken 0-60 from 7.6 to 7.0.
    I need some help though on the correct max boost pressure though. It is running max 0.8 bar and dips to 0.7. I was under the impression that it should run 1 bar max and then drop to 0.9. Am I correct for an auto box or are they designed to run lower to save the gearbox?
    Also on the gearbox I know they changed the final drive on the latter manual cars but did they also do this on the auto?
    Thanks in advance for any help.
  7. Remove Advertisements
+ Reply to Thread
  1. Sloooow Infotainment
    By NLHansB in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
    Last Post: 10-13-2005, 04:34 AM
  2. Too Sloooow!!!
    By robjgc1969 in forum Saab 9000 (1984 - 1998)
    Last Post: 07-25-2003, 04:54 PM
