Stuck alternator
Hello again, I recently posted about my electrical problems, and I have now bought a new alternator to put in my car (1991 Saab 9000 CD turbo). Managed to get it off it's bracket pretty easily, but found out that it wont fit through the "wheel arch" as the Haynes manual says!! I then tried to remove it from the top, but the alternator is too big to fit between the injector and top engine mount. I've spent a few hours now wrestling with it to see if it can fit trough in any other orientation. No luck. Any suggestions?
Re: Stuck alternator
I have to replace mine tomorrow morning. I was looking at the same issues you posted. It does look like there is a plastic/rubber "access" opening directly across from the alternator on the inside of the wheel well. I have already pre-guessed that the pulley needs to come off the alternator to fit thru the opening.
I will advise you tomorrow if I am correct. Might want to check it out on your '91
Chaps, to remove alternator take out the plastic wheel arch liners, then remove the metal strut from the sub-frame to the top of the inner wheel arch (its a long pole type thing!) now the alternator will slip out quite easily. Have fun
Originally posted by Adrian:
[qb]Chaps, to remove alternator take out the plastic wheel arch liners, then remove the metal strut from the sub-frame to the top of the inner wheel arch (its a long pole type thing!) now the alternator will slip out quite easily. Have fun [/qb][/b]
Thank You!!
wherewolfe
Adrian:
An addendum to your post...my '94 requires that I drain and remove the power steering pump in order to have a big enough opening to get the alternator out. I did remove the support bar, but unfortunately there still was not enough clearance. But, I thank your direction as it was invaluable.
Regards,
wherewolfe
By Simonsinc in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
Last Post: 04-19-2011, 07:11 AM
By zebthesaab in forum Saab 9000 (1984 - 1998)
Last Post: 06-26-2008, 04:20 PM
By adrian in forum Saab 9000 (1984 - 1998)
Last Post: 08-01-2004, 03:00 PM
By FoeCom in forum Saab 9000 (1984 - 1998)
Last Post: 07-10-2003, 01:45 AM
- You may not post replies
- You may not edit your posts
Forum Rules
