Bailey d/v
NEWS
+ Reply to Thread
Results 1 to 15 of 15
Thread: Bailey d/v
  1. #1
    Saab Afficionado
    Join Date
    Jul 2001
    Location
    Scotty land
    Posts
    1,673
    Bailey d/v
    I'm just about either fit a Bailey evo d/v to the car (K 2.0 LPT).
    Now the question is do I A)get an atmospheric d/v that has just two outlets eg bottom & top and blank off my the hole at the turbo end.
    Or B) get a recirculating valve,and not bother with the "whoosh", I was told by the boys at AVA (Zep & Ylee may have heard of them staying nearish the Glasgow area) that I could fit the atmospheric valve and blank off the hole at the turbo.
    I know I'm sounding vague but I dont what the hole is called that the side pipe the recirculating pipe goes into down at the turbo end,sorry.
  2. Remove Advertisements
  3. #2
    Saab Afficionado
    Join Date
    Sep 2001
    Location
    Norwich, Norfolk
    Posts
    1,925
    Re: Bailey d/v
    If your car is a standard LPT, then I'd say go for the recirculating one, as it won't be running much boost. You'll probably not get too much noise from an atmospheric D/V on the LPT.
  4. #3
    Saab Afficionado
    Join Date
    Jul 2001
    Location
    Scotty land
    Posts
    1,673
    Re: Bailey d/v
    Yes it's standard right now!,shame and here was me looking forward to a atmospheric valve.
    But I might still go for one the atm that is, cuase I may in the n/future get some tweaks here/there.
  5. #4
    Regular Saab Guy
    Join Date
    Apr 2003
    Location
    Gaithersburg, MD
    Posts
    79
    Re: Bailey d/v
    I fitted a Forge FMD004. Feels like a very solid unit, not super loud (like TurboXS or some of the others available), plus it is fully rebuildable. I think I read about someone on this board having a hell of a time rebuilding a bailey. Bailey wouldn't sell the spring or something to that nature. Search the archives and you'll stumble across the thread.
  6. #5
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Re: Bailey d/v
    If your car (as I suspect it will be as a 92/93lpt) is fitted with an AMM (Air Mass Meter) then you must fit a ricirculating type dump valve to avoid problems with fuelling (with an atmospheric you end up dumping air to the atmosphere that has already been metered, and that the ECU has calculated the correct amount of fuel for).
    The AMM (if fiitted) is located in the intake pipe between the air filter and turbo.
  7. #6
    Saab Afficionado
    Join Date
    Jul 2001
    Location
    Scotty land
    Posts
    1,673
    Re: Bailey d/v
    Originally posted by Mark E:
    [qb]If your car (as I suspect it will be as a 92/93lpt) is fitted with an AMM (Air Mass Meter) then you must fit a ricirculating type dump valve to avoid problems with fuelling (with an atmospheric you end up dumping air to the atmosphere that has already been metered, and that the ECU has calculated the correct amount of fuel for).
    The AMM (if fiitted) is located in the intake pipe between the air filter and turbo. [/qb][/b]
    Mark.....I was told by Bill Greer (Jimmy Mcrae's ex-mechanic) that I would need a double piston a/d/v.
    I did try an ordinary d/v (not the recirculating) and the car ran fine, but (as you know) wouldnt idle.
    So he's ordered a double piston valve which according to him and other Iv'e spoke to said that'll work fine, so I'll what happens when I get it.
    Stu
  8. #7
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Re: Bailey d/v
    Stu,
    The double piston arrangement is the internal configuration adopted by higher spec dump valves, atmospheric or not, in order to provide better response and greater reliability under higher pressures.
  9. #8
    Saab Afficionado
    Join Date
    Jun 2000
    Location
    Wolverhampton - bling capital of the Midlands
    Posts
    1,261
    Re: Bailey d/v
    The (single) piston design of dump valve was introduced to offer the benefits you describe Mark and is superior to the diaphragm design in those respects.
    However, the double piston configuration was introduced on atmospheric valves to prevent them leaking at idle. The vacuum at idle retracts the outer piston, leaving the inner piston sealing the valve.
    This will of course allow a car with AMM to idle properly, but will still do nothing to address the temporary rich condition immediately after the boost is dumped.
  10. #9
    Saab Afficionado
    Join Date
    Jul 2001
    Location
    Scotty land
    Posts
    1,673
    Re: Bailey d/v
    Thanks for the response from you all, but I still wait for the d/p/a valve,probably next week.
  11. #10
    Wastegate
    Join Date
    Sep 2000
    Location
    Mulbarton, was Deepest Mid Norfolk
    Posts
    8,810
    Re: Bailey d/v
    Saab1,
    So are you saying you are still going for an atmospheric one?
  12. #11
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Re: Bailey d/v
    Julian is absolutely correct...
  13. #12
    Saab Afficionado
    Join Date
    Jun 2000
    Location
    Posts
    1,261
    Re: Bailey d/v
    ....by the law of averages, it had to happen one day.
  14. #13
    Saab Afficionado
    Join Date
    Jul 2001
    Location
    Scotty land
    Posts
    1,673
    Re: Bailey d/v
    Originally posted by Scaero (ecopower stg0):
    [qb]Saab1,
    So are you saying you are still going for an atmospheric one? [/qb][/b]
    Yep!
  15. #14
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Re: Bailey d/v
    Originally posted by Saab1:
    [qb]Yep! [/qb][/b]
    Why, when it will cause problems with fuelling?
  16. #15
    Saab Afficionado
    Join Date
    Jul 2001
    Location
    Scotty land
    Posts
    1,673
    Re: Bailey d/v
    Mmmm,thats what he didnt tell me, but I guess he wants to sell so he wont.
    But then again, he's letting me "try before I buy", but are you talking about fuelling as in MPG wise?, cause other than that nothing's goin' to show up just with run round the block unless it really runs like **** .
  17. Remove Advertisements
+ Reply to Thread
  1. Bailey d/v
    By Stewart in forum Saab 9000 (1984 - 1998)
    Last Post: 06-16-2003, 04:30 AM
  2. Bailey Dump Valves
    By mpen in forum Saab 9000 (1984 - 1998)
    Last Post: 04-27-2003, 01:16 PM
  3. Bailey Dump Valves
  4. bailey dump valves
    By Anthony B in forum Help, Advice, Saabs and Motoring
    Last Post: 04-06-2002, 06:53 PM
