7 flashes of CHECK ENGINE!
NEWS
+ Reply to Thread
Results 1 to 4 of 4
Thread: 7 flashes of CHECK ENGINE!
  1. #1
    Saab Anorak
    Join Date
    Dec 2001
    Location
    Croydon, Surrey, UK
    Posts
    763
    Changed oil this morning & hit the road for Wales, just before Cardiff CHECK ENGINE light came on....checked at serviced station all appeared OK....WITH IGNITION ON THE LIGHT FLASHES 7 TIMES , CAR DRIVES FINE BUT HEAVY ON FUEL!
  2. Remove Advertisements
  3. #2
    Re: 7 flashes of CHECK ENGINE!
    Hi, mutungi.
    See here for the Trionic flash codes. Seven flashes is air/fuel mixture. If it is using a lot of fuel, then either the mixture is too rich due to a fault, and the teh code reflect this, or is has been too lean due to a fault and Trionic has made it very rich to compansate.
    Initially, I'd lean towards the former. A rich mixture on a Trionic engine could be due, as far as I know, to:
    1) Fuel pressure regulator
    2) Intake air temperature sensor
    3) Coolant temperature sensor
    www.saab9000.com - all you ever wanted to know about the Saab 9000
    www.saabits.com - stuff to help keep Saabs on the road
  4. #3
    Full throttle mark e's Avatar
    Join Date
    Jul 2002
    Location
    Leighton Buzzard
    Posts
    14,305
    Originally posted by BillJ:
    [qb]Hi, mutungi.
    3) Coolant temperature sensor [/qb][/b]
    4) An injector partially stuck open due to fault/clogging by dirt- check your plugs for tell tale signs
  5. #4
    Oh, yeah.
    All the others will make all plugs turn sooty. A faulty injector will affect only one plug.
  6. Remove Advertisements
+ Reply to Thread
  1. check engine light 3 flashes and 7 flashes
    By saabguy84 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 04-28-2011, 04:50 PM
  2. Check Engine 6 flashes
    By pandp in forum Saab 9000 (1984 - 1998)
    Last Post: 05-25-2009, 05:57 AM
  3. Check Engine - 6 flashes
    By TheFox in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 06-25-2004, 05:09 AM
  4. 4 flashes on 'check engine'
    By andycannon in forum Saab 9000 (1984 - 1998)
    Last Post: 02-21-2004, 01:47 AM
  5. 7 flashes of CHECK ENGINE!
    By mutungi in forum Saab 9000 (1984 - 1998)
    Last Post: 05-25-2003, 04:17 AM
