Help! Pipe fitting blowing off
NEWS
+ Reply to Thread
Results 1 to 4 of 4
Thread: Help! Pipe fitting blowing off
  1. #1
    Saab Afficionado
    Join Date
    Sep 2002
    Location
    Dorset, UK
    Posts
    1,749
    Last night I cleaned up the AIC and the throttle housing, but had a bit of a problem.
    The pipe that goes from the turbo side of the throttle butterfly to the AIC is clamped to a 2" piece of ~15mm copper tube, which looks like it was pressed into the alloy throttle body. The rubber pipe was good and stuck to the copper, and in the process of removal the copper piece came out of the throttle housing.
    I tapped it back in but it keeps blowing out under boost.
    Any ideas how I can refit it properly??
    Thanks!!
  2. Remove Advertisements
  3. #2
    Re: Help! Pipe fitting blowing off
    Perhaps give both it and the hole in the throttle body a really good clean with throttle body cleaner and give the outside of the tube (or the inside of the hole) a smear of Araldite before refitting?
    www.saab9000.com - all you ever wanted to know about the Saab 9000
    www.saabits.com - stuff to help keep Saabs on the road
  4. #3
    Saab Afficionado
    Join Date
    Sep 2002
    Location
    Dorset, UK
    Posts
    1,749
    I wondered about Araldite - someone at work suggested Chemical Metal. I went to Halfords where they had loads of variations on this theme and settled for something called "Kwik Weld" from the USA Let's see if it holds...
  5. #4
    Saab Afficionado
    Join Date
    Sep 2002
    Location
    Dorset, UK
    Posts
    1,749
    Well, the "Kwik Weld" is holding But when I overtook a truck yesterday, the small vacuum hose that connects to the inlet manifold/everything blew out, losing the rubber gromit in the process! New set of gromits all round, I think...
    I hope its just cos I fixed the vac leak and so the top boost pressure is higher, finding the weak points.
  6. Remove Advertisements
+ Reply to Thread
  1. Which diesel pipe is the supply pipe? 2.2 TID (125)
    By campbell mac in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 04-06-2011, 03:40 PM
  2. Can I make a new fitting for a radiator pipe?
    By James.r in forum Classic Saab 900 (1979 - 1993)
    Last Post: 05-10-2010, 05:31 AM
  3. A/C Blowing Hot Air - Help Please
    By warriorlane in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 08-04-2009, 08:34 AM
  4. fitting Abbotts fancy bit o pipe.....
    By andrewhayward in forum Saabscene: Performance
    Last Post: 07-24-2004, 04:03 PM
  5. Help! Pipe fitting blowing off
    By johncc in forum Saab 9000 (1984 - 1998)
    Last Post: 10-28-2002, 04:17 AM
