Not Horney but Washed Out
NEWS
+ Reply to Thread
Results 1 to 2 of 2
Thread: Not Horney but Washed Out
  1. #1
    Saab Newbie
    Join Date
    Jan 2002
    Location
    London - UK
    Posts
    2
    9000 CS 2.0i 1992
    Yesterday, driving to work, turn on wash/wipe & the thing goes ballistic! The pump & wipers going contnuously. Does not stop after 5 minutes. Stop the car, remove fuse #7 (10amps) [used for "Headlight Wipers"]& it stops! I had suspected the headlight wipers not working properly before.
    However, I find out later that the horn doesn't work!!! That should have been fuse #21 (25amps) which is for "Electric Throttle & Horn".
    So I temporarily put fuse #7 back in, the horn works, but the wash/wipe is going flat out again.
    What to do - I do NOT need the headlight washers, but we all get horney once in a while...
  2. Remove Advertisements
  3. #2
    Saab Anorak
    Join Date
    Oct 2001
    Location
    In front of my PC
    Posts
    970
    Re: Not Horney but Washed Out
    Yes indeed! Have you tested the relay for the wipers? I dont know if its the same one for windcreen wipers and h/lamp wipers. If it is then the windscreen wipers sould be ballistic too. If it is the same relay and the w/screen wipers are not moving then I suggest you test your switch.
    hth
  4. Remove Advertisements
+ Reply to Thread
  1. I washed it
    By john in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 10-20-2003, 08:53 AM
  2. Not Horney but Washed Out
    By 4Wheeler in forum Saab 9000 (1984 - 1998)
    Last Post: 01-08-2002, 01:03 PM
