Panel lights
NEWS
+ Reply to Thread
Results 1 to 3 of 3
Thread: Panel lights
  1. #1
    Panel lights
    I recently noticed that the "lights on" symbol in the tachometer was not illuminated and decided to investigate....Dash top off, instrument binnacle out, pictogram unit removed, speedo off, tacho out, nearly there...
    ...and, after removing the small circuit board containing the lamps, there it was at last! The smallest lamp in the world. I expected a standard panel lamp but found instead a sub miniature bulb measuring 6mm x 3mm dia. I switched over the still working TCS lamp temporarily, since I don`t get to make this come on too often.
    In case you need to replace one of these, they are available from Maplins stock code BT43 for about 30p.
    I also checked all the others, and there are an awful lot of lamps in there! Although the dash illumination seemed ok some 3 lamps had to be replaced due being blown and a couple more had poor connections so it was worth the hassle in the end.
    It must be Xmas tree light syndome that brought this on I suppose but at least there are no flashing sequences from the dash - yet!
  2. Remove Advertisements
  3. #2
    Motor Mouth
    Join Date
    Jun 2000
    Location
    Preston UK
    Posts
    2,599
    Re: Panel lights
    Thanks for the info Chris - I'll squirrel this one away for the future.
  4. #3
    Full throttle john's Avatar
    Join Date
    Jun 2000
    Location
    Sussex, UK
    Posts
    11,343
    Re: Panel lights
    chrisn, if it is any consolation, one of the fairy lights on my Christmas tree had gone, and the tail light/brake light twin element bulb on my classic 900 was shining brightly - luckily it is easier to get at then those inside the instruments on your 9000!
    All: remember, you can use the drop down menu to list topics older than 20 days - but you are welcome to squirrel away the advice if you wish!
    Regards
    /john
  5. Remove Advertisements
+ Reply to Thread
  1. SID panel and fog lights
    By kpac in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 03-01-2010, 02:55 PM
  2. Instrument panel lights
    By berkbs in forum Saab 9000 (1984 - 1998)
    Last Post: 03-29-2007, 11:24 AM
  3. Panel lights
    By spidermars in forum Saab 9000 (1984 - 1998)
    Last Post: 12-24-2002, 05:07 PM
  4. Panel lights
  5. Panel lights
    By chrisn in forum Saab 9000 (1984 - 1998)
    Last Post: 01-02-2001, 08:39 AM
