Air Conditioning?
I,ve just bought a 9000CSE (K reg '93 100Kmls)and the air con doesn't seem to be cooling adequately. I've mentioned it to the dealer I bought the car from but they said it wasn't a refridgerator. I've double checked with the hand book and I'm sure I've set the controls right. All the usual stuff, windows up etc. but it still feels cooler with the air con off and the windows open. How cool should it be? It's the standard air con, not the auto climate control.
Thanks.
Turbo Talker
Re: Air Conditioning?
After 7 years and 100k miles, your air-con may be due for a recharge. Cost is, I think, in the region of £80. A dealer or decent independent should be able to give the a/c a 'health check' for not much more.
HTH
James
Thanks James.
Dead right. I took it back under warranty and they re-gassed the a/c. Sorted.
Thanks again.
I heard a tip recently re; Saab air con.
You can check that the aircon pump seals are o.k. the following way;
Look at the area around the V-belt pulley on the pump unit. ( Usualy situated to left of radiator , as you stand in front of car,looks a bit like an alternator with coolant pipes going into it)
If the pump seals are leaking there will be signs of an oil mist spay near the pulley.
This would look dirty black with grime fairly quickly. If the seals go you will gradually lose gas & therefore cooling power over time. My own car has these symptoms & the aircon is pretty feeble. Question is how long will a recharge restore the cooling for? I've yet to spend the dosh to find out.
An engineer friend states that any decent refridgeration engineer( see yellow pages) should be able to do a recharge for a fraction of the cost of Saab main dealer. Again I've yet to confirm this. Anyone tried it?
If you have a leak of refridgerant, a recharge will not last long. I had my system re gassed shortly after getting the car, and the during the first long run the cooling rapidly declined due to a leak on the compressor to evaporator hose (rubber / union joint)
At the compressor, there are 2 connection points for gas and oil, and they are different sizes. Some independants don`t have the appropriate adaptors. I believe the correct way is to evacuate the system and leave it that way for some minutes with a vacuum gauge attached to test for leaks. If you have any, reach for the credit card -aircon components are expensive ! I think its a question of checking exactly what the engineer proposes to do....
Thanks for the advice Chris. Are you saying that the pump has an oil supply of it's own?
Or just that it can be topped up?
since winters coning maybe I should just do without.
William - if you have a look at the top of the A/C compressor next to the plastic connector in its clip, there should be a silver label on it. On this is the serial no, SAAB part no and the oil capacity of 135cc. So yes it has a supply which should be checked when the system is re charged.
Also look at the large hose from the comp to the evaporator which should have the gas code such as R12 on it. You may have a different gas recommended as these refidgerants are updated, but I don`t know the current SAAB recommendation - does anyonelse ?
R134A is the only refrigerant currently allowed. Older cars with R12 can still be re-charged but R12 is apparently getting hard to find and expensive.
Saab Afficionado
I agree about R12. I have just had the ACC on my 1991 2.3 CSE turbo converted, from R12 to R134A, checked and recharged for £95+VAT. I am embarrassed to admit that the ACC had never worked in the 4 + years I've had the car!
Turbo Talker
I would like to find ANYONE who can do this conversion and find the leak in mine.
Saab Afficionado
Zaphod, can you tell us where they are. Are they on this planet?
Saab Afficionado
Try www.stgeorge.co.uk - based in Bristol, mostly harmless.
By mark bailey in forum Saab 9-3 Sport Saloon / Convertible / Combi (Estate)/TurboX/AWD (2003 - on)
Last Post: 05-06-2009, 11:27 AM
By sussex2 in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
Last Post: 08-07-2005, 01:55 PM
By djtaylor in forum Saab Recommendations
Last Post: 07-05-2005, 07:11 AM
By Denny in forum Saab 9000 (1984 - 1998)
Last Post: 07-01-2003, 01:28 PM
By del940 in forum Saab 9000 (1984 - 1998)
Last Post: 06-27-2003, 12:13 PM
- You may not post replies
- You may not edit your posts
Forum Rules
