HELP! Radiator fan always on!!
NEWS
+ Reply to Thread
Results 1 to 3 of 3
Thread: HELP! Radiator fan always on!!
  1. #1
    Saab Newbie
    Join Date
    Jul 2000
    Location
    Broadford, Isle of Skye, Scotland
    Posts
    3
    The car is a 1992 9000 CSE 2.3T DI with ACC.
    The radiator fan is on at all times with the engine running or not, even when the key is out of the ignition, and the only way to stop it running is to remove the fuse.
    All electrical connections seem to be fine, and all fuses are sound.
    Any suggestions would be greatly appreciated in helping me solve this problem.
    Angus M Smith
    Isle of Skye
    SCOTLAND
  2. Remove Advertisements
  3. #2
    Saab Fan
    Join Date
    Jun 2000
    Location
    Farnham, UK
    Posts
    54
    Re: HELP! Radiator fan always on!!
    Hi Angus,
    Lovely part of the world - but I bet fuel prices are horrendous.
    In answer to your question, I can only think it'll be either the relay ("above" the fuses - you have to slide the glovebox out and drop the hinged tray that holds the relays to get to them) or a temperature sensor. Alas I don't know enough to be sure of my answer, but I'll look into it, or find a man who knows what he's talking about!
    Phil.
  4. #3
    Saab Afficionado
    Join Date
    Jun 2000
    Location
    Forfar,Angus Scotland
    Posts
    1,242
    I'm the man who Phil thinks that I know what I'm talking about, I'm not so sure as Phil.
    As Phil says it could be the relay. If I remember rightly on your car it's not behind the glove box but in the auxilliary fusebox in the engine compartment along with the headlight relays and fuses near the front N/S. The temperature switch is on the radiator at the O/S bottom, in front of the turbo and below the ACC compressor. You could disconnect the wires (they are spade connectors) and see if the fan stops - don't attempt this with the engine running or if it is hot. If the fan stops it is the switch which is duff.
    Unfortunately the ACC also operates the fan under certain conditions but I don't have the details of that so I'd be guessing there
  5. Remove Advertisements
+ Reply to Thread
  1. Radiator fan.
    By mazy in forum Saab 9000 (1984 - 1998)
    Last Post: 07-21-2008, 04:04 PM
  2. radiator
    By 99bazza in forum Saab 99, 90 (1969 - 1984)
    Last Post: 03-17-2008, 04:55 PM
  3. radiator fan
    By deano in forum Saab 9000 (1984 - 1998)
    Last Post: 08-12-2004, 06:53 AM
  4. radiator
    By chris baillies in forum Saab 99, 90 (1969 - 1984)
    Last Post: 07-10-2002, 06:05 PM
  5. HELP! Radiator fan always on!!
    By Angus M Smith in forum Saab 9000 (1984 - 1998)
    Last Post: 07-24-2000, 09:07 AM
