TTID problem Not revving above 4000 RPM
NEWS
+ Reply to Thread
Results 1 to 6 of 6
Thread: TTID problem Not revving above 4000 RPM
  1. #1
    Need help now
    Have gone through your post and cleaned the following
    ERG Valve
    MAP Sensor
    EGR Pipe
    Outer Throttle Body & Butterfly
    Air Filter as had leaves and crap
    However, Starts Fine run to red line then Idle, after a few minutes cannot rev past 4k
    Shutdown & restart and able to red line again
    Few Minutes back to 4k only
    There is a very slight shudder on the power up from 800 up til 2k.
    Have no Codes or Warning on the SID, have not had diagnostic check yet.
    Is there anything i have missed. Car has been fine up to Wednesday last week
    Saab 9-3 1.9 TTid Vector Sport on a 09 plate
    Many Thanks
    Bryan
  2. Remove Advertisements
  3. #2
    No Power ( Help )
    Need help now
    Have gone through the posts and cleaned the following
    ERG Valve
    MAP Sensor
    EGR Pipe
    Many Thanks
    Bryan
  4. #3
    Re: TTID problem Not revving above 4000 RPM
    Hello
    I've created a new thread for you as the o,d thread was from 2013 , and the person in question has not been on for atleast 8 months .
    Have you followed the other cleaning thread
    http://www.saabscene.com/forum/threa...-BODY-Cleaning
    Also when was the last time the car regenerated itself ?
    I would be inclined to get the problem looked at if you have followed the above .
  5. #4
    Quote Originally Posted by lizzard-t View Post
    Hello
    Yep all of the above. How do you get the car to regenerate itself please?
  6. #5
    Drive it on a clear straight road keeping revs above 2500 rpm for about half an hour , turn back and do the same , if it's regenerating you will find your DTE and MPG will fall , and you may get some smoke from the exhaust that's quite normal it's just the soot being incinerated.
    But fist of all check oil level ( make sure it's not too high and sniff the oil on the dip stick to make sure it don't smell of diesel ) if any of the 2 above are present then change oil and filter first .
  7. #6
    Regular Saab Guy
    Join Date
    Feb 2016
    Location
    France
    Posts
    77
    Need to get it on a code reader see what that tells you.
    2010 93 Aero TTiD Manual
  8. Remove Advertisements
+ Reply to Thread
  1. 05' 9-5 Aero Boosting Problem not holding after 3 RPM's
    By dmontoya816 in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 04-16-2014, 09:52 AM
  2. Most efficient RPM range (Ttid)
    By Jonesinamillion in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 01-10-2013, 08:18 PM
  3. Saab 9-3 Aero ttid struggles past 3000 rpm
    By simonfarrell in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 04-06-2012, 11:46 AM
  4. Revving problem
    By dickyh in forum Saab 9000 (1984 - 1998)
    Last Post: 07-21-2004, 10:20 AM
  5. Revving problem
