changing expansion ank on a 93 6 cyl.?
NEWS
+ Reply to Thread
Results 1 to 7 of 7
Thread: changing expansion ank on a 93 6 cyl.?
  1. #1
    Saab Newbie
    Join Date
    Sep 2016
    Location
    belgium
    Posts
    6
    Hi can anyone tell me how to change the expansion tank on a 6 cyl?
    I don't know how to disconnect the lowest pipe.
    Thanks!
  2. Remove Advertisements
  3. #2
    Re: changing expansion ank on a 93 6 cyl.?
    7mm Spinner perhaps?
  4. #3
    Saab Newbie
    Join Date
    Sep 2016
    Location
    belgium
    Posts
    6
    I 've never heard of a 7mm spinner..
    Do I need a special tool to open or remove the hose clamp?
    This lower tube/pipe is very difficult to reach and I don't want to damage it!
    Thanks!
  5. #4
    Is the hose clamp , the crimped type ? . If so then you will prolly damage it , I've never come across one of them that can be reused . I normally replace them with a jubilee clip , which requires either a 7 MM spanner , or a flat blade screwdriver to tighten up .
  6. #5
    Saab Newbie
    Join Date
    Sep 2016
    Location
    belgium
    Posts
    6
    Yes indeed, I think it's a crimped type (never seen one like this). The pipe is difficult to reach so removel of the clamp(with cutting plier) will not be easy.. . Is there some special tool for this?
  7. #6
    If I'm proved wrong then I'll Ho,d my hands up . But I think there's only a special tool for crimping them together . I've removed them before , but prolly in a more accessable area than yours seems to be in .
    I normally get a flat blade screwdriver in there and work it around . To relieve it's stubbornness
  8. #7
    Saab Anorak
    Join Date
    Dec 2003
    Location
    Peterborough,Cambs,UK
    Posts
    813
    Grab a copy of the WIS it will tell you all!
    http://www.saabcentral.com/forums/sh...d.php?t=622081
    The clips push back to release.
  9. Remove Advertisements
+ Reply to Thread
  1. '96 2.3L 4 cyl. Water pump
    By Jewel613 in forum Saab 9000 (1984 - 1998)
    Last Post: 05-24-2011, 09:48 AM
  2. Clutch Master Cyl
    By dave225 in forum Saab 9000 (1984 - 1998)
    Last Post: 11-05-2008, 02:30 PM
  3. changing master/slave cyl
    By woolfie in forum Saab 9000 (1984 - 1998)
    Last Post: 12-01-2003, 01:27 PM
  4. changing master/slave cyl
  5. Master cyl clutch
    By microcat36 in forum Saab 9000 (1984 - 1998)
    Last Post: 09-27-2003, 04:55 AM
