Autoboxes ? Ideally the 5 speed Jobby on a Aero 210 (2006 & others) - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: Autoboxes ? Ideally the 5 speed Jobby on a Aero 210 (2006 & others)
  1. #16
    Re: Autoboxes ? Ideally the 5 speed Jobby on a Aero 210 (2006 & others)
    I took mine to a transmission specialist in the end & £190 later the transfer from gear to gear is faultless
    I will be doing further servicing my self tho'
  3. #17
    Quote Originally Posted by J..M View Post
    Well done...
    Its good when you actually can feel the difference. It proves it was ready for doing.
    Your wallet may be smarting but nothing like the £1800 it costs to have the box rebuilt!!!
    I just thought I would get a quote whilst I was having my ATF drained.
  4. #18
    £1800 is chronic...... I'd be down to the scrappers looking for a Vectra/Insignia to pillage
  5. #19
    I woukd not be down the scrap yard pillaging a vectra or insignia .
    I woukd be on a street corner swinging my handbag .
    COS if £1800 is the cost to have the gearbox rebuilt , I would feel as if I've been F****d well and truly.
  6. #20
    Nov 2016
    UK
    21
    What was the mileage ?
  7. #21
    47k.......
  8. #22
    Quote Originally Posted by lizzard-t View Post
    Yeah..... The last Manual box I had removed rebuilt & replaced was £330..... I thought that was pretty good
  9. #23
    I have to hand it to you Mr Lizzard, You do have a way with your descriptions.. :-)
  10. #24
    [QUOTE=J..M;1412402]I took mine to a transmission specialist in the end &
    Can you tell me who did the ATF change for you? I still have our soft-top's ATF to change in June and after the XWD's experience, I'm really not looking forward to it!
    In fairness, my Saab specialist kept at it until they sorted it (four full flushes in the end) and the car seems fine now - fingers still crossed though! Nevertheless it might be less stressful to use a good autobox specialist.
  11. #25
    autogearboxservices.co.uk
  12. #26
    Saab Anorak
    Dec 2003
    Peterborough,Cambs,UK
    813
    I did this job myself on the vert a couple of years ago and although time consuming is fairly easy to do.
    The capacity is around 7L for the 6 speed.
    A drain empties around 2.75L so to achieve a 90% turnover you need to do 4 changes.
    For the inbetween changes I just put in the 2.75L and on the last followed the procedure to check the level by run off from the drain tube and then overfill as per wis instructions.
    I did this over a period of a few weeks driving the car in between.
    For the adventurous you can tap into the ATF cooler lines and then empty and fill with the engine running.
    I didnt have the courage to do it that way as I was wary of completely emptying the gearbox in a few seconds!
    I will be doing this job again over the summer on a recently acquired Sportwagon
    Found this online
    http://www.ebay.co.uk/itm/3221933371...%3AMEBIDX%3AIT
    Saab spec supported.....
    https://translate.google.co.uk/trans...3/&prev=search
  13. #27
    Thanks for that!
  14. Remove Advertisements
  1. Brake Disc Minimum Thickneses ...... Aero 210 2006
    By J..M in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 01-30-2017, 02:05 PM
  2. clutch on a 2006 Aero 210
    By norrie in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 01-06-2015, 03:35 PM
  3. Aero 210 5 or 6 speed. What dates?
    By philmots in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 03-29-2011, 03:53 PM
  4. 2003 9-3 Aero 210 holding back & engine management light, SAI?
    By sjeffrey in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 01-19-2011, 12:02 PM
  5. saab 9-3 aero(210) convertible 5 or 6 speed
    By HAMMY2891 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 08-13-2008, 05:02 PM
