2010 TTiD Fault codes
NEWS
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Thread: 2010 TTiD Fault codes
  1. #1
    Saab Fan
    Join Date
    Feb 2016
    Location
    France
    Posts
    71
    On my recently bought a 2010 Aero TTiD this morning the EML light came on and it was miss firing first turn of the key. I went to work and it was a bit rough and mpg was way down.
    A couple of hours later it ran fine but with the EML on.
    I have an OpCom and did a scan using the Zafera B option. I have no idea if it is accurate as not meant for the Saab.
    Found 2 codes
    P0202-04
    P1125-62
    I have WIS and did a fault code search using EDC16 ECM (Is this the correct option?)
    P0202 didn’t have a -04 code and all the other P0202 said it was indicator fault but Autodata shows it as a injector 2 circuit malfunction. Which is correct?
    P1125 didn’t have a -62 code but P1125-08 showed throttle actuator incorrect signal.
    Could somebody tell me if the Opcom is worth using or should I just get a Tech2? Do you ignore the -04 -62 bits?
    And is Autodata or WIS correct?
    2010 93 Aero TTiD Manual
  2. Remove Advertisements
  3. #2
    Saabisti
    Join Date
    Oct 2005
    Location
    Cornwall
    Posts
    159
    Re: 2010 TTiD Fault codes
    Just did a quick search and can confirm that those codes don't seem to exist in the WIS.
    Is the Zafira the correct car to be trying to connect as? I would have thought a Vectra or an Astra would be more appropriate.
    As for Autodata or WIS - my money is on the WIS being correct but we need to certain that we have the correct codes first.
    Frank.
  4. #3
    Saab Fan
    Join Date
    Feb 2016
    Location
    France
    Posts
    71
    Thanks Frank
    If the light comes back on I will try again with Vectra and Astra before clearing them.
    I only used Zafira as I found a post where somebody had successfully used it.
    I could see live data and cleared the codes ok.
    Any particular Vectra or Astra to use? Don’t think they used the twin turbo engine
  5. #4
    Insignia bi-sexual,,,,,,,,,,,,,,,,,,,,,,,,, no bi-turbo
  6. #5
    Saab Fan
    Join Date
    Feb 2016
    Location
    France
    Posts
    71
    OK will try Insignia bi anything
  7. #6
    Saab Newbie
    Join Date
    Nov 2016
    Location
    UK
    Posts
    15
    I am assuming the EML was yellow? It may be worth adding a DPF cleaner to the fuel and giving it a 30 minute motorway blast! Just a thought.
  8. #7
    Saab Fan
    Join Date
    Feb 2016
    Location
    France
    Posts
    71
    Yeah yellow is there a different colour?
    Have a receipt to show DPF was recently removed and cleaned out, I had the exhaust off at the DPF (clamp was not put on) and it looked ok inside.
    OpCom said DPF was at 60%.
    I don’t do a lot of short journeys I have a Peugeot with a DPF for 5 years not had problem with that.
  9. #8
    Saab Newbie
    Join Date
    Nov 2016
    Location
    UK
    Posts
    15
    I believe it can go to 'red'!
  10. #9
    Saab Fan
    Join Date
    Feb 2016
    Location
    France
    Posts
    71
    Ok tried it again today. When you have been using lots of revs/boost the engine light comes on and it runs a little rough.
    Got the same two codes (Using Vectra this time) now gives text description.
    P0202-04 Injector 2 circuit malfunction (if injector 2 is 2nd from left looking at the engine the clip is damaged but connected)
    P1125-62 Throttle Actuator Malfunction
    I reset the codes again and ran the car normally (no huge acceleration) No engine light but the Throttle Actuator Malfunction came back.
    Have found how to fault find both in WIS will try that when I can what a stupid place to put the ECU no wonder they get damp
  11. #10
    Saab Fan
    Join Date
    Feb 2016
    Location
    France
    Posts
    71
    Throttle body is broken the cogs inside have stripped spindle wasn’t moving at all.
    Anybody got a spare one?
  12. #11
    Neo Bro's are saying £175..... Could it be repaired ya think by a man in a workshop that enjoys a challange ?
  13. #12
    Saab Fan
    Join Date
    Feb 2016
    Location
    France
    Posts
    71
    If I can get the gears I could probably do it. Think I have found a used one for about £50. Anymore and would just get a new one.
    The number 2 injector plug is damaged. Garage must have damaged it when they changed an injector seal got a receipt just before I got it they broke the connector then bent the pins in to try make a contact.
    Will order a plug repair kit for that.
    Cleaned the EGR, EGR pipe and MAP sensor while I was at it. EGR wasnt bad at all bit the pipe was fairly blocked as was the MAP sensor.
  14. #13
    Should you at some point get bored ..... & as ya likes cleaning stuff....... Nip over & run a sponge over my Aero will ya
  15. #14
    Saab Fan
    Join Date
    Feb 2016
    Location
    France
    Posts
    71
    Quote Originally Posted by J..M View Post
    Lol still got loads to do on this the sump is coming off when the replacement oil pick up seal arrives. Not had a good look yet but think fair amount has to come off to get the sump off.
    Got rear discs and pads to do tomorrow.
    Enjoying working on this after a few years of Peugeots
    For what I paid for it expected to do some work just didnt know what.
  16. #15
    Modern cars huh ! .... Doncha just love em' ........ They never give you enough room to swing the hammer tho' ...... Kinda rude really !
  17. Remove Advertisements
+ Reply to Thread
  1. Silver 2010 Aero TTiD
    By richfr in forum Saab Forecourt
    Last Post: 03-11-2017, 05:59 AM
  2. Key codes don't exist late 2010 onwards
    By BKS in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 08-11-2015, 04:52 PM
  3. 9-3 TTiD 2010 Ashtray
    By Tricamel in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 08-22-2014, 08:53 AM
  4. help with fault codes stability fault
    By jamster in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 10-01-2013, 12:05 PM
  5. My 2010 19.TTiD Vert
    By Blunders500 in forum Saab Forecourt
    Last Post: 04-29-2013, 12:55 PM
