Low coolant level warning
NEWS
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Thread: Low coolant level warning
  1. #1
    2008 1.9 TTid
    For about a month now I have been getting the "Bing Bong" tone and the message "Low coolant..Add coolant"
    The car only does this once during warm up (usually when the temp is between a quarter and the normal half way mark)..
    For the first dozen times it did it I raised the bonnet to check the coolant level. Its always been exactly at the correct level..
    I am assuming the culprit will be a faulty level sensor within the coolant bottle?
    What are your thoughts ?
  2. Remove Advertisements
  3. #2
    Saab Afficionado
    Join Date
    Mar 2012
    Location
    United Kingdom
    Posts
    1,017
    Re: Low coolant level warning
    Not personally heard of this issue before, though I suspect someone will have. I'm not even aware that the coolant tank has any form of level sensor, so if it has, that's a new one on me!
    Do you know when the last time the coolant was flushed/replaced? I'm assuming it was probably done whenever the last cambelt/waterpump replacement was carried out? Is the coolant a nice shade of pink?
  4. #3
    Yep there's a float sensor on the side of the tank , sometimes they get curdled up and can send the sperror message .
    Make sure coolant is up to the higher mark at the bottom of the arrow .
  5. #4
    Saab Afficionado
    Join Date
    Mar 2012
    Location
    United Kingdom
    Posts
    1,017
    Ya learn summat new every day!
  6. #5
    Quote Originally Posted by Caddyman View Post
    They did a partial drain / replacement of the coolant when I had the cam belt / water pump done..
    I may well take upon myself to renew the lot..
    Not that I am tight but I will remove the coolant tank and give it a good shake with some hot soapy water in it before I put it back in place.
    The colour of the coolant in the bottle I would describe as an off pink.. Dusky pink.. Certainly not a vibrant new type of pink..
  7. #6
    Off pink is the new colour for this season !
    Just done my thermostat , which must of been installed by trolls
    And refilled with pink , and yes it comes out off pink
  8. #7
    If you can leave this till summer more the better ....... My thinking straight off the Bat is airlock ........ The only real way to remove one of those without days of dickking about is to empty everthing follow the instructions opening the bleed valves & closing.... & deffinately not filling it at a high rate of knotts so to speak ....... Say if you were to empty everything & just do the refill proceedure with plain water & try it for a week ya would have some idea of whether it was a poorly recharged cooling system or No ? ....... Then Obv's drain everything again once you've prooved the system with a ..... Err 55% mix of antifreeze which I guess means a further 45% of water ...... Then pick the car up under ya right arm & shake it ..... Just to mix everything up ......Nahh, OK but ya can see where I'm coming from tho'..... & plain water is a tad cheaper than antifreeze & theres no trying to save the old stuff if things go Bosseyed...... Which experiance has taught me ..... Happens !
  9. #8
    Another good point....
    It doesnt go "Bing Bong" every time but it certainly does it say 4 out of 10 cold starts...
  10. #9
    Umm ..... I recon' ya might have to bite the bullet then ........ Dooya have large patio doors over at "SSPEED Towers"..... So we could move the sofa & work on the TTid in ya dining room or what ever? ...... I hate being cold
  11. #10
    When I moved in here I had to replace all the joists under the floor cos the git that sold it me, sold it with VERY bad dry rot.
    Strangely it didnt touch the floor boards but ate the joists...
    They then covered the floor with very cheap crappy laminate flooring.
    I then learnt that even if you pay for a full structural survey that the surveyor is NOT allowed to lift a laminate floor..
    Beware if you are buying a property..If you see cheap laminate floors then be very suspicious.. Apparently the cowboy building fraternity know of this little scam !!
  12. #11
    Saab Afficionado
    Join Date
    Mar 2012
    Location
    United Kingdom
    Posts
    1,017
    We've gone totally off topic here, but that's the beauty of buying a new build house, the downstairs floors are all concrete!
  13. #12
    Quote Originally Posted by sspeed View Post
    Well yes & no ....... Drilling the odd hole to pass a endoscope through should be favourable to not checking at all ..... Still we are where we are :/
  14. #13
    Ever tried lifting laminate flooring , then putting it back down again ? It don't happen
    It's like it's on laminate viagra !
    As for concerete floors yep they have there pros and cons ,
    Pros , cheap to lay ( like a ten pinter) ,
    Cons , if up to about the year 2000 services ( gas , water , ) were laid under neath it in strengthened copper or should of been ,
    And then tested for soundness then wrapped in denso tape .
    Ummmm that's all ok if done properly .
    But after about 20-30 years the cement is eating away at the denso , and then eats the copper .
    Outcome , ( if you have a water meter ) the needle is spinning even with all outlets off
    The gas side -------- when tightness testing you find a drop outside tolerance, but no smell of gas .
    Both are leaking in the concerete and no visiable signs of smells of gas . Your conerete floor has suddenly become a floating gas bomb ,
    Always full of optetmisum me !
  15. #14
    Laminate bloody flooring ..... Posh git ..... Get Lino
    Bitta piping slapped on the outside, then in thro walls as required ? ..... I dunno, ugly as hell..... But less stress
  16. #15
    Yep down here in wick , we're posh, our F***s smell of roses , and we cock our little finger up when drinking our ginger beer !
    As for pipe work on the outside of house , down here anything made of any kinda metal on the outside of your house woukd be gone by the next morning .
  17. Remove Advertisements
+ Reply to Thread
  1. coolant level low warning
    By drmick in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 12-10-2014, 01:18 PM
  2. coolant level low warning and No Cabin Heater
    By H7AYD in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 12-04-2008, 01:12 PM
  3. Coolant Level Low
    By TimR in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 10-22-2007, 04:57 AM
  4. COOLANT LEVEL LOW intermittent warning!
    By katzumi in forum Classic Saab 9-3 & GM900 (1994 - 2002)/Conv ( -2003)
    Last Post: 01-26-2007, 09:58 PM
  5. Coolant level low
    By blert596 in forum Help, Advice, Saabs and Motoring
    Last Post: 12-31-1969, 07:00 PM
