p1109 - (9) code what is it?
NEWS
+ Reply to Thread
Results 1 to 10 of 10
Thread: p1109 - (9) code what is it?
  1. #1
    Hi all,
    9-5 1.9 2006 Vecta Sport auto.
    I slapped the opcom reader on the car today because it has gone into and is repeatedly dropping into limp mode. turn off, reset it start again and she will reve fine. the moment I back off the fuel and go into overrun, it drops into limp.
    My gut is telling me I have a blocked DPF. but I would like to post the fault codes here if that is Ok and maybe you can tell me otherwise.
    p1109 - ( 9 )
    p1109 - ( 0 )
    My op-com unit is telling me it is unknown dtc error on everything so thats not ideal
    The software I have is 2010, if anyone can point me in the direction of newer that would be appreciated also.
    Thanks in advance
  2. Remove Advertisements
  3. #2
    Saab Fan
    Join Date
    Feb 2016
    Location
    France
    Posts
    71
    Re: p1109 - (9) code what is it?
    From SAAB WIS
    P1109 Swirl Actuator Incorrect Feedback Signal.
  4. #3
    For which code? there are two different codes above one is (9) the other is (0) ?
  5. #4
    Join Date
    Nov 2009
    Location
    Cheshire.Uk
    Posts
    4,783
    p1109 is swirl actuator.
    My 9-3 audio,2 x cd changers,aux-in & Bluetooth audio streaming..
    Is still running Factory oe coils with a tune..
  6. #5
    Thanks both
    so I need to sort that out then
  7. #6
    Quick update, I have looked and the connection rail to the flaps was wired up (not connected) I opened the flaps to 10 o clock, but no joy.
    Got my daughter to get in and rev the car, number 3 is not moving at all when revving.
    Should I assume then that either the actuator has gone, or the connection rod from the actuator to the flap has come away or similar?
    Any further advice appreciated.
  8. #7
    Another question, is it not possible to disconnect the no3 or the unit itself in situ? (dreaming I know )
  9. #8
    Another update (As I hate it when people come to a forum for help, get what they want and then leave).
    I managed to get into a position where I could see behind the intake manifold and get eyes on the link bar (the small black plastic one on the valve NOT the connection rail that links the flaps). The bar has detatched from the swirl actuator, but is still attached to the swivel flap the other end.
    What appears to have been happening is that on the overrun, the swivel actuator was trying to close, but as the link had detatched, it was snagging the actuator and sending back an error message. I pulled it through and as a VERY temporary measure (to prevent it going into limp) wired it in the open position so the link bar can't snag the actuator.
    Well it worked, the car is no longer going into limp.
    I fully understand this is not a long term option, and am not advocating it as a fix to the problem. What I am saying is that this is what happened to me, and that now my intention is to get it all done properly.
    Can the tech guys here tell me, is it possible to change the link bar without dismantling everything?
    I have seen the modification kit to the connector rail and will look at getting that changed.
  10. #9
    Join Date
    Nov 2009
    Location
    Cheshire.Uk
    Posts
    4,783
    was the rod moving atall..
  11. #10
    The rod had come adrift at the valve end, but was still connected to the flap end. That is moving freely and when I manually move it in and out the swirl flap in the inlet manifold is rotating as it should.
  12. Remove Advertisements
+ Reply to Thread
  1. P1109 Fault code 1.9TID Auto HELP...
    By Conor62 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 07-07-2015, 07:07 PM
  2. Code error P1109
    By saab4ever2020 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 10-17-2014, 01:26 AM
  3. p1109 error
    By shauny598 in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 03-30-2011, 02:37 PM
  4. Error code P1109
    By nicknsoph in forum Classic Saab 9-5 (1997 - 2009)
    Last Post: 03-27-2011, 04:29 AM
  5. P1109 fault codes
    By ahthud in forum Saab 9-3 Sport Saloon / Combi(Estate)/TurboX/AWD (2003 - on)/Convertible(2004 - on)
    Last Post: 03-11-2010, 04:24 PM
